Lotus Exige Cup And Lotus Exige Cup 240
Road Cars Ready for Track Use – Straight out of the Box:
Lotus Sport, the motor sport division of Lotus Cars Ltd., has developed two higher
performance versions of the 2006 Model Year Lotus Exige, the Lotus Exige Cup and the Lotus
Exige Cup 240, both developed for track use straight out of the box.
The Lotus Exige Cup cars are based on the new 2006 Model Year Exige and are completely
track ready sports coupés with uprated clutch, sports exhaust, adjustable suspension, uprated
brakes, limited slip differential, switchable traction control, a T45 steel roll-over hoop and Aframe
with harness mounts, fuel and ignition kill switches and a fully plumbed in fire
extinguisher system. An FIA approved 6 point roll cage is a no cost option*.
As the names suggest, the Lotus Exige Cup cars are available with two different engine
variants. The Lotus Exige Cup uses a 192 PS (189hp / 141kW) and 181Nm four cylinder 1.8
litre 2ZZ VVTL-i engine, and the Lotus Exige Cup 240 uses a supercharged and intercooled
high revving 1.8 litre four cylinder engine producing 247 PS (243hp / 181kW) at 8000 rpm and
a torque figure of 236 Nm at 7000 rpm.
Performance from both the variants is phenomenal with the Lotus Exige Cup reaching 100
km/h in 5.2 seconds and 160 km/h in 13.2 seconds, with a top speed of 237 km/h. The Lotus
Exige Cup 240 reaches the 100 km/h mark in around 4.5 seconds and 160 km/h in 11.3
seconds. Top speed is 249 km/h.**
Both versions are built as official factory conversions of new Lotus Exige cars by Lotus Sport
at its facilities at the Group Lotus Headquarters in Hethel, Norfolk, UK. Each car features a
Lotus Sport build plate.
The specifications in more detail:
Apart from the differences in engine performance, the Lotus Exige Cup cars have identical
specification.
Engine
The Lotus Exige Cup uses a 192 PS 2ZZ-GE 1.8 litre VVTL-i (Variable Valve Timing with Lift –
intelligent) engine. This high revving engine is governed to a maximum engine speed of 8500
rpm with a change between two cams (a high speed cam and a low speed cam) at between
5800 rpm and 6200 rpm depending upon the operating conditions of the car.
The supercharged and intercooled engine in the Lotus Exige Cup 240 has a maximum power
output of 247 PS (243 hp / 181 kW) at 8000 rpm and a torque figure of 236 Nm at 7000 rpm.
This vast amount of extra power and torque now available means that the cam change
between the low-speed cam and the high-speed cam now takes place at around 4000 rpm
giving a smooth and linear surge of power from 4000 rpm all the way to the maximum 8300
rpm. The Roots-type Eaton M62 supercharger (with a sealed-for-life internal mechanism
meaning that it does not require the use of the engine’s oil) is run from the crankshaft, and has
an integral bypass valve for part load operation. Charge air (air under pressure from the
supercharger) is cooled through an air-to-air intercooler (the cooling air enters via the roof
scoop) before being fed into the engine itself. All charge air ducting has been kept as short as
possible with large diameter pipes making sure that the bends in these ducts are not too tight,
to the benefit of throttle response and efficiency. Four high capacity injectors add additional fuel
under hard acceleration or high speed driving.
A sports-type clutch plate and heavy duty clutch cover transfers the engine power and torque to
the lightweight C64 six-speed gearbox (with an aluminium casing) – with the same perfectly
spaced ratios as the standard Elise 111R and Exige.
A torque-sensing type limited slip differential is fitted as standard and works in harmony with the
Lotus switchable traction control system. The system works though the engine, reducing power
to maintain traction, is active above 8 km/h and operates much more quickly than many brakebased
systems.
An Accusump (engine oil accumulator unit) is included in the whole package as an oil reservoir
backup for extreme track use ensuring that, under these conditions, the engine oil pressure
remains constant.
Wheels and Tyres
Y-type 8-spoke lightweight cast alloy wheels in High Power silver are shod with Lotus specific
Yokohama Advan A048 tyres (rated W and annotated with “LTS”) to maximise grip and achieve
the ride and handling targets set by Lotus.
Brakes
The brake system includes cross-drilled and ventilated discs and upgraded sports brake pads
set into the brake calipers (AP Racing on the front and Brembo on the rear), high grade silicon
brake fluid, stainless steel braided brake hoses all linked to the proven Lotus track tuned servoassisted
four-channel ABS system that enhances braking performance and minimising stopping
distance without taking over from the skill of the driver.
Suspension
Suspension is provided by Öhlins springs and two-way adjustable dampers (which have 22
compression and 60 rebound settings and ride height adjustment to reduce the ride height from
130 mm to 120 mm) and an adjustable front anti-roll bar (five settings). Full instructions and
recommended settings are provided to allow customers to tailor the handling characteristics of
the car to their own requirements.
As the Lotus Exige Cup cars are modified for track use, a double shear track control arm brace
is provided to cope with the expected kerb abuse during racing and hard track day driving.
Safety Equipment
The Lotus Exige Cup cars have all the safety equipment that is expected for a track car with 4
point seat belt harnesses (for track use only), two sports seats clad in suede-effect material
and using ProBax technology, a T45 steel roll-over hoop and A-frame with harness mounts, a
mechanical ignition kill switch with cockpit and external activation and a plumbed electrical fire
extinguisher system, again with cockpit and external activation. A FIA approved 6-point roll
cage is a no cost option, race ready for customers wishing to compete in motorsport activities.
Interior
The interior makes use of lightweight and simple race specification materials including
aluminium window winders, acrylic capped door panels and carbon-effect leather door inserts.
Exhaust System
A “Level One” stainless steel sports exhaust is fitted with the bifurcated exhaust pipes exiting
from the centre of the anodised-finish 3-piece rear diffuser. Front driving lamps, twin oil coolers
and air conditioning* complete the equipment package for the Lotus Exige Cup cars.
The Lotus Exige Cup has a Recommended Retail Price of 47,621+VAT in mainland Europe
and CHF83,948 including all taxes in Switzerland.
The Lotus Exige Cup 240 has a Recommended Retail Price of £45,995 in the UK,
  • Replies 8
My Exige Cup 240 car should be with me in about a week or so, just in time for the snow ;)
The cars been built and is now on it's way to Motorsport for the extras and SC fitment. First customer car of a 50 limited run :P
What the press statement doesn't say is that both Road & Track versions are available. The road version so doesn't have the Fire extinguisher or electrical cut off (dissables the alarm).
lotus press items and specs are abit confusing. I've now got 4 versions of the specification, so god knows what'll turn up Especialy as they didn't fit the electric windows and C/L I was after (but got a nice discount instead).
Ooh, CHROME ORANGE ;)
Electric windows and central locking ;)
Pehaps they couldn't believe someone would order that for a track car :P
Interesting.
I don't think that is one of the Cup 240 cars under production now. More likely to be the old Exige Cup with the addition of the SC. I know that mine will be the first customer car, and that only 1 will be built before that (Lotus' own, being built now).
They do not mention the traction control or LSD, so it will be interesting to see how that helps the 0-60 time. Might show the skills of the test driver up...
