Set-Up Guide - Hungarian Grand Prix
Set-up Guide - Hungaroring
Engine
We are looking for non-peaky power delivery to facilitate traction out of the low-speed corners as well as good all round driveability.
Brakes
There are relatively heavy braking demands heading into turn one as it is at the end of a comparatively long straight. From turns four to turn 10 the braking demands are very light, so drivers need good confidence in their braking systems as heavy use is relatively seldom over the course of a lap.
Suspension
The circuit layout promotes understeer so you need a strong front end to prevent this. The car needs to ride the kerbs a lot at this track so a soft front end can assist.
Rear Wing
The rear wing configuration runs to maximum downforce levels.
Tyres
The soft and supersoft Pirelli P-Zeros are allocated. The circuit surface and layout is relatively kind to the tyres, however the high temperatures frequently experienced can cause the rubber other issues, such as blistering.
Front Wing
Maximum downforce for the circuit layout and also designed to help counter understeer; we will run a new specification front wing to assist with this.
Track Annotations - Hungaroring
  • Turn 1 - Heavy braking from almost 300 kph to under 100 kph. The most likely overtaking opportunity on the circuit.
  • The track is downhill into turn two so there is potential for drivers to outbrake themselves into this corner.
  • Turns four to eleven very much lead into each other so there's little braking here. You need a well-balanced car with good change of direction capabilities.
  • Turn 13 - The second slowest corner on the circuit taken at around 100 kph.
  • It's crucial to get a good exit from the 3rd gear turn 14 as it leads onto the only straight, which, in turn, heads into the best overtaking opportunity into turn one.
  • The Hungoraring is a circuit where the surface grip level improves a lot over the course of a race weekend, which makes finding the correct set-up a challenge – has a lap time improvement come from a change to the car, or from the track surface improvement?
http://www.lotusrena...Grand-Prix.html
User Feedback
  • Lotus in the Peak Digital info Files
    Please find Digital LitP info below.  Please ensure you are logged into the MLOC forum and then click this link:  Note there Are No Physical Tickets Please print off any of the info contained as you feel necessary. There are:- Map links for the run locations. GPX files. Your final instructions. A full runs group list - please note your group number and leader's name. A copy of the Safety Brief. Important - If you are taking part in a Sunday m
    Elisemadray
    Elisemadray
    General Talk 7
    Hi. I’ve not received my pack yet for for Sundays LITP. Has everyone else received there’s yet or am I worrying unduly ?
    Vince Licata
    Vince Licata
    General Talk 2
    VIEWING
    Can I get peoples thoughts on this  my lack of knowledge on models I thought this car would have had the Rover engine  its a 2010 1.8S but has a supercharger fitted producing 218bhp cant seem to paste the link but looks a stunning car
    Timsrs
    Timsrs
    Technical Talk 2
    Lotus in the Peak info
    Hi all that have booked for this years LitP all final info will be emailed out Thurs/Fri please check your spam thanks the LitP team
    Elisemadray
    Elisemadray
    General Talk 4
    Formula One
    Maddox
    Maddox
    General Talk 4
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,439
    Total Members
    1,800
    Most Online
    jimmy_c
    Newest Member
    jimmy_c
    Joined
