R31 - Silverstone Set-Up Guide
"Silverstone is one of the classic F1 circuits. Compared with the last few Grand Prix races, it offers a very wide range of challenging corners which range from fiercely quick to quite slow and technical. Having such a large difference between the fast and slow places a heavy demand on both the driver and his race engineering team to extract the most from the car." said Technical Director James Allison.
Set-up Guide of Silverstone
Engine
The layout of Silverstone is reasonably hard on the engine due to a high average rpm over the course of a lap. It has an impact on fuel consumption but the Renault V8 engine is very good in this area.
Brakes
In complete contrast to places like Canada or Valencia, where we battle to keep the brakes cool, here we battle to keep them hot enough. Silverstone is very easy on the brakes, as there is relatively little brake usage because so many of the corners are high speed. When you do actually need the brakes they can be quite cold so you have to ensure they stay warm enough to function correctly.
Suspension
We've got a new geometry front suspension to try, which we will evaluate on one of the cars on Friday. There isn't a great deal of kerb usage or anything in particular which relies on any particular aspect of the suspension, as this is more of an aerodynamic efficiency type of circuit. You need a stable car through the high speed corners like Copse, Maggots, Becketts and Chapel, and this achieved through a combination of the aerodynamic balance and suspension settings.
Rear Wing
After three street courses, Silverstone is a return to a slightly lower level of downforce and aerodynamic efficiency, which is king. Our new DRS rear wing worked well at Valencia so we are hoping that this carries true for Silverstone too.
Tyres
Silverstone is quite hard on tyres because of the high speed corners and it's not dissimilar to Barcelona in this respect. There has been some resurfacing to Copse, the highest speed sections of the track which could have an impact on tyre wear. Pirelli decided to bring their soft and hard compound.
Front Wing
You may carry a little bit more front wing than at other places in order to balance the car in the high speed corners. This also helps minimise understeer through Brooklands and Luffield, which is vital for a good entry speed to the following straight and on through Copse and into the Becketts complex.
Track annotations
  • New pit complex so a new environment for the team
  • Vale is one of the slowest corners, taken at 100km/h
  • Stowe is approached at over 300kph
  • The bump at Abbey has been 'addressed'
  • The new section of the circuit for last year has been well received
  • It's essential to minimise oversteer through Lufield to ensure good speed onto the straight, through Copse and into Becketts complex, and onto Stowe
  • Drivers will have to remember not to look for the pit boards here!
  • Taken almost flat out, Copse is one of the mose daunting corners of the season.
  • It's resurfaced this year
  • Overall car balance is essential through the Becketts complex which is entered at over 300kph
http://www.lotusrena...k-comments.html
User Feedback
  • Lotus in the Peak Digital info Files
    Please find Digital LitP info below.  Please ensure you are logged into the MLOC forum and then click this link:  Note there Are No Physical Tickets Please print off any of the info contained as you feel necessary. There are:- Map links for the run locations. GPX files. Your final instructions. A full runs group list - please note your group number and leader's name. A copy of the Safety Brief. Important - If you are taking part in a Sunday m
    Elisemadray
    Elisemadray
    General Talk 7
    Hi. I’ve not received my pack yet for for Sundays LITP. Has everyone else received there’s yet or am I worrying unduly ?
    Vince Licata
    Vince Licata
    General Talk 2
    VIEWING
    Can I get peoples thoughts on this  my lack of knowledge on models I thought this car would have had the Rover engine  its a 2010 1.8S but has a supercharger fitted producing 218bhp cant seem to paste the link but looks a stunning car
    Timsrs
    Timsrs
    Technical Talk 2
    Lotus in the Peak info
    Hi all that have booked for this years LitP all final info will be emailed out Thurs/Fri please check your spam thanks the LitP team
    Elisemadray
    Elisemadray
    General Talk 4
    Formula One
    Maddox
    Maddox
    General Talk 4
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,439
    Total Members
    1,800
    Most Online
    jimmy_c
    Newest Member
    jimmy_c
    Joined
