Kit: Spanner Set. Socket Set. Wire Wool. Silicon sealer. WD40. Copper Grease or similar. Any bolts that look knackerd that hold the shocks.
Day before: spray all nuts and bolts holding shocks with WD40
Slightly loosen all wheel bolts
Jack one side of car up, chock wheel
Remove wheel your working on
Undo the two bolts holding shock on
Remove old shock
On rears: fit new shock, noteing that shock is correct way up. zip tie speedo cable to shock body on LHS, ensuring it has enough slack not to strech all the way through wishbones travel. tighten bolts. Clean wheel and hub faces. Grease faces with copper grease. re-fit wheel
On fronts: remove old shock. remove nuts holding old bracket. clean chassis where bracket sits. apply sealer to back of bracket (to prevent corrosion). re-fit bolts holding bracket. fit shock right way up. Clean wheel and hub faces. Grease faces with copper grease. re-fit wheel
Drop car back down.
Tighten bolts.
Repeat on other side.
Get car geo'd (Although apparently you can get away with just having the toe set).
I think thats pretty much it! IIRC
User Feedback
  • TRD Airbox for Elise
    nick_t
    nick_t
    Technical Talk 13
    Evora 400 Audio Upgrade?
    Jas
    Jas
    Technical Talk 2
    PJT
    PJT
    General Talk 17
    Elise K Series Upgrade
    William D8on
    William D8on
    Technical Talk 68
    Adventures of an S1 Elise in Germany
    Some of you will know, but for the rest, I'll be working in Germany near Mannheim until end of 2026 with 75% of my time there, and 25% back home. As i fancy doing some different roads, and I've booked two weekend driving tours with Delightful Driving company (run by Elisa Artioli), on Thursday 10th July I'll be setting of in my S1 Elise, and 4 days later I plan to arrive at my apartment. I plan to post about my driving adventures over there, so keep an eye on this blog should you be in
    Badger02
    Badger02
    Touring 105
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,628
    Total Members
    4,445
    Most Online
    zhelinm
    Newest Member
    zhelinm
    Joined
