From experience, if you want to wire a shift light into you 111s you might encounter the same problem that I did. Most shift lights can be wired into the ECU feed to the rev counter in the Stack unit. I initally tried this, but the shift light worked either intermittently or not at all.
Through a bit of reserch I found out that I would be better wiring the shift light feed to the signal to the coil pack, which is different on the VVC engine to a standared K.
Dave Andrews had this advice to give me:
"I would expect that the shift light would need a coil signal to calculate RPM, usually the low tension switch side of the coil is used for a signal so you might want to consider connecting to that either at the coil pack (tricky dicky) or at pin 25 of the MEMS.
The tacho signal from pin 12 is sometimes too 'square' for tachos/shift lights etc. The coil trigger signal (pin 25) is more of a round waveform and is sometimes better to use."
So I tried wiring it to the coil pack (low tension side) and bingo!, it worked!
You'll find that there are three wires on the low tension side, you should be able to use either of the outside wires. Just remember to set the Shift Light to 2 Cylinder mode, as it is now only receiving a signal for two of the cylinders!
User Feedback
  • Spotted at British Motor Show
    ...does it count if you spot yourself? I joined the SELOC stand at the British Motor Show last week. There were half as many time machines* there as Lotuses! (Well I'm exaggerating actually because there was a Lotus Carlton on another stand and a 340R in the supercar section. Maybe next year I should cross link to the SELOC events page as it would be great to have a bit more of a showing and I know MLOC has some members a bit further south. Enjoyed having a bit of time this aftern
    kayj_prod
    kayj_prod
    General Talk 3
    Toxic Green S-Cup - (Aka Grogu)
    Hi all as with most of my cars I thought I’d start a bit of a build thread. However unlike most cars which I bought and built up to be highly modified the plans for the lotus are quite different and so this will be more thread of its life in my ownership. I have also created a Facebook page called “Toxic Green S-Cup - (Aka Grogu)” containing images of its progress pre and post purchase. Build Page Guide Page 1 * Pre-purchase Photo‘s * First maintenance wash * Trip to Brands Ha
    DC2-CJH
    DC2-CJH
    Garage 40
    Elise S2 111R MFRU multi function relay unit replacement
    Hi Everyone, I need to replace the MFRU on my Elise 111R and I am looking for some advice please. Firstly, can this be done from above, or is it necessary to remove the under tray and do it from below? I am uncertain how much slack are in the connector leads. Also, should the unit simply slide up and off the mounting tab, or is it locked somehow, as mine won't budge. Is there a locking tab that needs to be deflected to unlock the unit. I can't find anything anywhere about thi
    Simon Chapman
    Simon Chapman
    Technical Talk
    Accident Repairers
    Devastatingly I've just had a low speed collision in my Evora - less than 5mph but the front bumper/valance panel is damaged; does anyone know of a decent specialist who can repair/replace the panel - the insurance companies approved repairer will probably be no good - I'm in South Yorkshire  - please help kind regards  Richard
    Richard Bell
    Richard Bell
    General Talk 1
    For sale
    I have for sale a s2 factory short hard top in azure blue . Its currently for sale on ebay if anyone is interested.   Thanks .
    daz-man
    daz-man
    MLOC TV
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,642
    Total Members
    4,445
    Most Online
    Simon Chapman
    Newest Member
    Simon Chapman
    Joined
