It is possible to bleed the brakes using the traditional 2 person technique (1 pushing the pedal and 1 controlling the flow through the nipple) however a pressure bleeding system (such as a Gunsons Eezi-bleed) makes it a relatively easy 1 person job. The basic procedure with an Eezi-bleed is as follows:-
  • Fill Eezi-bleed bottle.
  • Connect Eezi-bleed cap to resevoir
  • Connect air pressure feed to tyre (checking for leaks).
  • With a clear hose attached and feeding into a jar, undo bleed nipple using a ring spanner. Continue until fluid is bleeding clear and without bubbles. Nip up the bleed nipple.
  • Repeat for all corners, possibly going round the set a couple of times. The usual procedure is to start with the longest brakelines, i.e. nearside-rear, offside-rear, nearside-front, offside-front.
  • Keep checking the Eezibleed resevoir. If you need to top it up DONT FORGET TO TAKE OFF THE AIR SUPPLY before removing the top!
  • When done disconnect air supply and remove Eezibleed.
  • Use a torque wrench to tighten the bleed nipples (if you have a torque to set them to and a wrench available). You can do this by hand, but it is tempting to overtighten them.
  • Give the nipples a spray with brake cleaner to clear them and the calipers of excess fluid.
  • Try the brake pedal.
  • Check the calipers/nipples for any signs of leakage.
  • Top up resevoir and replace cap.
The biggest problem bleeding a dry system (e.g. following following a brake hose or caliper change) is removing air from the front calipers. The layout of the front caliper is such that there is a void in one half of the caliper thats is difficult to bleed with the caliper in the fitted position. Arguably the best way to remove air in this pocket is to remove the caliper from the upright and bleed the caliper whilst rotating it in a steady 360deg arc, repeating the process until no further air bubbles come out and the pedal becomes firm.
User Feedback
  • Spotted at British Motor Show
    ...does it count if you spot yourself? I joined the SELOC stand at the British Motor Show last week. There were half as many time machines* there as Lotuses! (Well I'm exaggerating actually because there was a Lotus Carlton on another stand and a 340R in the supercar section. Maybe next year I should cross link to the SELOC events page as it would be great to have a bit more of a showing and I know MLOC has some members a bit further south. Enjoyed having a bit of time this aftern
    kayj_prod
    kayj_prod
    General Talk 3
    Toxic Green S-Cup - (Aka Grogu)
    Hi all as with most of my cars I thought I’d start a bit of a build thread. However unlike most cars which I bought and built up to be highly modified the plans for the lotus are quite different and so this will be more thread of its life in my ownership. I have also created a Facebook page called “Toxic Green S-Cup - (Aka Grogu)” containing images of its progress pre and post purchase. Build Page Guide Page 1 * Pre-purchase Photo‘s * First maintenance wash * Trip to Brands Ha
    DC2-CJH
    DC2-CJH
    Garage 40
    Elise S2 111R MFRU multi function relay unit replacement
    Hi Everyone, I need to replace the MFRU on my Elise 111R and I am looking for some advice please. Firstly, can this be done from above, or is it necessary to remove the under tray and do it from below? I am uncertain how much slack are in the connector leads. Also, should the unit simply slide up and off the mounting tab, or is it locked somehow, as mine won't budge. Is there a locking tab that needs to be deflected to unlock the unit. I can't find anything anywhere about thi
    Simon Chapman
    Simon Chapman
    Technical Talk
    Accident Repairers
    Devastatingly I've just had a low speed collision in my Evora - less than 5mph but the front bumper/valance panel is damaged; does anyone know of a decent specialist who can repair/replace the panel - the insurance companies approved repairer will probably be no good - I'm in South Yorkshire  - please help kind regards  Richard
    Richard Bell
    Richard Bell
    General Talk 1
    For sale
    I have for sale a s2 factory short hard top in azure blue . Its currently for sale on ebay if anyone is interested.   Thanks .
    daz-man
    daz-man
    MLOC TV
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,642
    Total Members
    4,445
    Most Online
    Simon Chapman
    Newest Member
    Simon Chapman
    Joined
