Inability to open the rear boot can stem from a number of sources:-
  • Poorly set boot catch
  • Stiff catch or cable
  • Broken cable
If the cable is intact then request an accomplice to 'jiggle' the bootlid whilst pulling on the catch. More often than not the catch will release and the bootlid come up.
If the cable is broken toward the handle, it is possible to remove the rear offside wheel liner and reach in and pull on the cable.
If, despite all other attempts, the boot lid will not come open it is possible to remove the number plate and drill a hole (c.15mm) in the centre of number plate aperture in the rear clam. A suitable implement such as a screwdriver can then be used to trigger the catch. Although this sounds extreme, the hole is easilly covered by a grommet or tape followed by the numberplate and therefore not noticeable when reassembled.
If the bootlid repeatedly sticks due to poor alignment then the pin should be adjusted (see below).
User Feedback
  • VIEWING
    Can I get peoples thoughts on this  my lack of knowledge on models I thought this car would have had the Rover engine  its a 2010 1.8S but has a supercharger fitted producing 218bhp cant seem to paste the link but looks a stunning car
    Timsrs
    Timsrs
    Technical Talk 2
    Lotus in the Peak Digital info Files
    Please find Digital LitP info below.  Please ensure you are logged into the MLOC forum and then click this link:  Note there Are No Physical Tickets Please print off any of the info contained as you feel necessary. There are:- Map links for the run locations. GPX files. Your final instructions. A full runs group list - please note your group number and leader's name. A copy of the Safety Brief. Important - If you are taking part in a Sunday m
    Elisemadray
    Elisemadray
    General Talk 6
    Lotus in the Peak info
    Hi all that have booked for this years LitP all final info will be emailed out Thurs/Fri please check your spam thanks the LitP team
    Elisemadray
    Elisemadray
    General Talk 4
    Formula One
    Maddox
    Maddox
    General Talk 4
    School prom 21st June help
    Can anyone with an unusual Lotus help me out this Saturday 21st about 6pm in south Derbyshire. So my lad has his school leaving prom this Saturday, some of you will have met Jasper helping out with the parking or sound system at past LITP’s.  As I take Jasper to school in my Evora everyday he doesn’t think it’s special, so I sorted that his friend is going to go in my Evora and I was borrowing my mate Wayne’s S1 Exige to take him as something a bit different .  Unfortunately Wayne’s S1 has
    chris_h
    chris_h
    General Talk 7
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,439
    Total Members
    1,800
    Most Online
    jimmy_c
    Newest Member
    jimmy_c
    Joined
