Pie Warrior Posted June 7, 2022 Share Posted June 7, 2022 Hi guys, my indicators do not work first thing after start up, but if I turn on the Hazards and then turn them off after a few seconds the indicators work fine Link to comment Share on other sites More sharing options...
Lithopsian Posted June 7, 2022 Share Posted June 7, 2022 Clicker module might be getting tired. More current from the hazards could force it into life. Easy to replace, plug and play. Or the panel switch is dodgy. Might be grit inside or corrosion on the contacts. Might be able to fix with loads of contact cleaner and liberal amounts of switching on and off. Might need to take off the dash and remove the switch for a proper cleanout. Might need to buy a new switch. Link to comment Share on other sites More sharing options...
