Ortope Posted January 17, 2020 Share Posted January 17, 2020 I am restoring my Exige S1 from 2000. The car was, unfortunately, modified in several aspects and I am trying to bring it back to the original specs. Could some one please let me know what kind of oil cooler was mounted originally on the car and what type of fitment were used to fix the hoses it on the filter housing and on the radiator. As far as I know the hose should be a SAE 100R6 Thank you for your help. Adriano Link to comment Share on other sites More sharing options...
russelld Posted January 17, 2020 Share Posted January 17, 2020 My car is an early S2 Elise 190 K series ( 2003 ) which I think has the same oil cooler take off. If you can find out if it does I can remove the undertray and take some photos for you. AFAIK the cooler is long, linea & front mounted behind a front undertray similar to my S2. Again I don't mind taking photos if you find out that's the case. This shows the filter housing with the take offs : https://www.deroure.com/diagrams.asp?TBL=1671&MAK=1&MDL=16&SMA=0&SMO=0&ST=&SC=0 This shows oil cooler and pipe routing : https://www.deroure.com/diagrams.asp?TBL=1688&MAK=1&MDL=16&SMA=0&SMO=0&ST=&SC=0 Russ Link to comment Share on other sites More sharing options...
Ortope Posted January 17, 2020 Author Share Posted January 17, 2020 The diagram you sent me look the same. Probably the filter housing will be the same (Rover-K engine); part # A111E6146F The spare part number of the radiator is: A111K0036F Actually a Setrab oil cooler number 52-05635 is mounted on the car (see pictures attached) Thank you for your help Link to comment Share on other sites More sharing options...
