Mac1967 Posted September 28, 2005 Share Posted September 28, 2005 Hi Guys, I need some advice please. When I purchased my Elise Type 23, it came with a Pipercross induction filter (but not fitted). I've now decided to pop it on and see what difference it makes (looking for noise difference really)... but... Should I stick the Pipercross on or go for a Hurricane system?? Is there really any difference or great preference? I don't really know much about either of them so some advice would be greatly received. Also... will a different induction system change the mixture? Will the ECU compensate for this? Am I barking up the wrong tree? Geeeez.... Thanks guys Regards, Mac Link to comment Share on other sites More sharing options...
Steve J Posted September 28, 2005 Share Posted September 28, 2005 Probably not enough of a difference to justify swapping. I assume the K&N has a cold air feed, otherwise it'll be sucking in hot air from around the engine. Hurricane looks better and gives a better sound, but not much in it. ECU has no problems with these kits. Link to comment Share on other sites More sharing options...
Mac1967 Posted September 28, 2005 Author Share Posted September 28, 2005 Hi Steve, The one that came with the car (although not fitted) is just a cone filter with a small linking tube - No tube leading to the side air intake so there would be no feed from the air intake...so I take it this is no good? Regards, Mac Link to comment Share on other sites More sharing options...
Scrappydog Posted September 28, 2005 Share Posted September 28, 2005 Hi Steve, The one that came with the car (although not fitted) is just a cone filter with a small linking tube - No tube leading to the side air intake so there would be no feed from the air intake...so I take it this is no good? Regards, Mac <{POST_SNAPBACK}> If you want noise, then stick the Piper cross on. It will sound better, but because it's sucking in hot air from the engine bay you will not get an performance increase. You may actually get less performance on hot days. If you want a very marginal increase (1-2bhp) then stick an enclosed filter kit which takes air from the side air intake; Hurricane kit, etc. If you don't really care for either, then don't bother. Andy Link to comment Share on other sites More sharing options...
Paul_C Posted September 28, 2005 Share Posted September 28, 2005 if you already have the PiperX you may aswell stick it on and see what it sounds like for the sake of 1/2 hr fitting it!! you will like it, and not want to take it off, i promise. put a bit of flexible ducting from the side vent, blowing onto the filter. cable tie it to that steel strut that braces the chassis. sorted Link to comment Share on other sites More sharing options...
Steve J Posted September 28, 2005 Share Posted September 28, 2005 Just fit what you have. The cold air ducting will help and you'll have the same effect as a Hurricane (although more home-made) Link to comment Share on other sites More sharing options...
GCCK Posted September 28, 2005 Share Posted September 28, 2005 The purpose of the pipe means you can put the cone near to the nearside air vent, so the air feed will be cold enough. I have a Pipercross cone on the end of my cold air box (for d2htb's). AFAIK Hurricane is the only induction system which tries to seal the path from the vent to the cone - do they claim a ram-air effect? ITG produces similar or better power figures (at 2x the price) but is positioned near to the vent as per Pipercross. So in conclusion: fit the Pipercross - it's as good as any! Link to comment Share on other sites More sharing options...
Carlylove Posted September 28, 2005 Share Posted September 28, 2005 Fit one! Go for a Blat! Fit the other! Go for a Blat Cant really tell the difference? You can! Fit that one, you will be happier Noise = worth it Responsiveness of engine = worth it Whatever you decide never second guess your decision! There are enough to**ers out there to TRY and do that for you! Enjoy Link to comment Share on other sites More sharing options...
Mac1967 Posted September 28, 2005 Author Share Posted September 28, 2005 Thanks for the advice guys, The Pipercross that came with the car (although unfitted) is just a simple cone with no additions longer pipe to draw cold air from the side vent. I think I'll stick it on and see what happens. I might then try adding some longer tubing to get the cold air effect and see if there is any difference. Thanks for all your advice...I now know a little more what I'm doing. I'll let you know how I get on and how it sounds. Regards, Mac Link to comment Share on other sites More sharing options...
