Posting Pictures From A Mac !
Hi all.
Has anyone posted pictures on here from a Mac, as I seem not to be able to regardless of what I try !
So if anyone has, can they help me into what I'm doing wrong :-((
If not may have to Email someone one here and let them post them up for me......
Ps I tried the methods from last time but none of them worked grrrrrr
Your patience is welcomed
Regards Chris
  • Replies 7
I'm sure there are plenty that have, there are physical server limits on the size of uploads and also account limits, if you are trying to upload an image directly from a camera it is likely to be too large in size and dimensions. Check out the FAQ's here and see if that helps as there are a few topics on this?
http://www.midlandsl...ms/#entry211061
Are you getting an error message when uploading? You need flash 9 to use the advanced uploader, if not you will also see a link that says: "Trouble uploading? Try our basic uploader"
Post back if none of that helps.
As you can see its not working for me !!!
Wont try anymore untill i know for sure, as i dont want to fill up the forum with random
words and numbers !!
Hi Chris, the link you posted is to the file locally on your pc.
Can you explain the steps you are doing to try and post an image, are you trying to upload the image or just link to it?
Morning Mark.
Basically I click on choose a file, this then brings down all my photos.
I then click on the image I want, then click choose.
And to the side of the choose file box it displays the image number & jPG
I then click attach this file.
And Error No file was selected for upload !!
I know it's something I or the Mac's not letting me do. I've never had any issues emailing pictures....
Thanks so far
Chris.
Hi Mark..
I have done it, i think, a little small but I think there viewable :-)
Thanks
Chris.
I always post from my Mac and the only thing I have to to do first is re-size. If its just a quick photo on my iPhone, I just email it to myself with the small setting which normally suffices. If it's a photo already within iPhoto, I just drag the photo onto the Preview icon in the dock which will immediately open it, then Tools... Adjust size. I save it out to the desktop as the re-sized version.
Remember it is the file size which has to be under 100kb and so by fiddling with the jpeg quality options you can get a larger image for the same data size.
Thanks for that I knew there would be a way.
Good point on the jpeg size
Cheers Chris.
