richbk Posted September 4, 2005 Share Posted September 4, 2005 hi guys,a few words of advice to ease my worries please. just got my car back after metal coolant hose replacement,carried out at stratstone in brum. very helpful considering they sell astons and jags only. coolant level in tank was just below maximum on collection. drove 80 miles home,steadyly up m6,keeping eye on temp gauge. it was constant at 87 when running rising to 90-93 in traffic and at lights. no problems. when i got home and lifted lid the coolant tank was full to brim and hissing is this normal,or do i have a problem left for 2 hours and level had returned to max. but after short run this morning same thing is happening. is hissing due to fact that pressure release on lid popped when i had initial problem ,does it need to be replaced many thanks rich Link to comment Share on other sites More sharing options...
christurbo Posted September 4, 2005 Share Posted September 4, 2005 Your water level should be around the min mark, maybe it has too much in it, thus when rising causing pressure and the hissing noise. Take it down then test it. Link to comment Share on other sites More sharing options...
richbk Posted September 4, 2005 Author Share Posted September 4, 2005 Your water level should be around the min mark, maybe it has too much in it, thus when rising causing pressure and the hissing noise. Take it down then test it. <{POST_SNAPBACK}> will give it a go later, stuck at work now,in this heat,with no hope of an afternoon run - how gutted am i cheers Link to comment Share on other sites More sharing options...
Mark H Posted September 4, 2005 Share Posted September 4, 2005 Replace the cap they are only £3.50 or so. If it carries on hissing I would get it pressure tested just incase. I'm pretty sure JohnnyM had these symptons so it might be worth PM him. Link to comment Share on other sites More sharing options...
Mark H Posted September 4, 2005 Share Posted September 4, 2005 BTW - He did have a HGF after it as well Link to comment Share on other sites More sharing options...
richbk Posted September 4, 2005 Author Share Posted September 4, 2005 BTW - He did have a HGF after it as well <{POST_SNAPBACK}> thats put my mind at rest what symptoms should i look out for, for hgf as am concerned lack of coolant my have done some damage Link to comment Share on other sites More sharing options...
malbon Posted September 4, 2005 Share Posted September 4, 2005 dont worry about it. sounds like just an air block. there is a bleed screw just off one of the inlet pipes to the header tank. get the car up to temperature and let some air out. careful not to burn. is your oil ok. i.e mayo in oil ? any shit you can see floating in the header tank ? if this doesnt work get it pressure tested at lotus or rover. also check your cap as beefy says as thier success rate is something sill like 3 out of 10 caps Link to comment Share on other sites More sharing options...
Mr_Belowski Posted September 4, 2005 Share Posted September 4, 2005 sorry to hijack the thread, but on the subject of pressure caps, could a dicky one cause a slight hissy whistling when warming up? If I wanted to replace it, are they cheap and easy to find for an S1? Order from a dealer perhaps? rich - most posts I've read on the matter suggest a 'normal' level is nearer min than max when cold, so maybe just overfilled? Link to comment Share on other sites More sharing options...
malbon Posted September 5, 2005 Share Posted September 5, 2005 caps can be got from lotus or rover. no more than a fiver but ive had 2 failed ones before getting it right. Header fill should be just above min when cold. If it pressurises right up then goes back to normal on cold then chances are its an airlock If it pressurises and then goes to well below min then chances are its beeing evaporated out the exhaust as steam and will be inlet manifold problem or head gasket. Link to comment Share on other sites More sharing options...
