Nick S1 Posted June 15, 2003 Share Posted June 15, 2003 I have a problem with the rev counter on my S1, sometimes it works sometimes it doesnt. The times that it doesnt work if I tap on top of the stack the needle sparks into life and works until I turn the ignition off. Last week it gave up all together, no amount of tapping on top of the stack would get it to work again. Ive had a look through the archives and a few people with similar problems have cured it by removing the stack and reseating the multi plug at the back of the stack. Friday I removed the stack, removed the multi plug, cleaned the contacts refitted and it still didnt work. I repeated the above procedure 3 times and on the third attempt the needle sparked into life. Everything was OK Friday and Saturday but while out today it has started dying and then coming back again! Does anybody know which wire on the multiplug at the back of the stack is the signal wire for the tacho? My thought is that there may be a faulty connection in the plug or perhaps the fault is in the stack itself? Ive also posted this on the BBS so sorry to anyone who has read it twice but all help is much appreciated Nick Link to comment Share on other sites More sharing options...
Wuddie Posted June 15, 2003 Share Posted June 15, 2003 Maybe this could be the sensor at the wheel end? if the stack looks fine, then i'd start trying to trace the wheel sensor down, has the car been up on ramps recently (before this started), on my last car (bmw) if the car was up on ramps o on the cagrage lifts then for a while after the abs sensor on the wheel would have come loose and i'd need to get it sorted..maybe this could be something similar Link to comment Share on other sites More sharing options...
Nick S1 Posted June 16, 2003 Author Share Posted June 16, 2003 wuddie thanks for the advice but the rev counter gets its pulses directly from engine speed and not from a wheel sensor. I have removed the plug at the 'engine end' of the connection but this made no difference thanks anyway nick Link to comment Share on other sites More sharing options...
Wuddie Posted June 16, 2003 Share Posted June 16, 2003 oops sorry!!! guess i dont know much afterall when you do find a fix..post back and let us all know! Link to comment Share on other sites More sharing options...
Mark H Posted June 19, 2003 Share Posted June 19, 2003 I'd start here http://www.stackltd.com/ Only other thing I can suggest is to try someone elses stack in your car and you can work out if its the wiring or stack unit that is the cause of the problem. Link to comment Share on other sites More sharing options...
