gerags Posted August 5, 2005 Share Posted August 5, 2005 Right. I've got an Eliseparts exhaust manifold gasket as I need to replace the old one. Has anyone replaced this before ? How involved is it ? I've searched SELOC and all they say is "it's an easy" and "the gasket was too thin and I needed to fit washers" but nothing on the technicalities of swapping it. (And there's nothing in the service manual) Any advice you may have would be much appreciated. Cheers. Steve. (Edited for cak spelling) Link to comment Share on other sites More sharing options...
jimbobdunkley Posted August 9, 2005 Share Posted August 9, 2005 Right. I've got an Eliseparts exhaust manifold gasket as I need to replace the old one. Has anyone replaced this before ? How involved is it ? I've searched SELOC and all they say is "it's an easy" and "the gasket was too thin and I needed to fit washers" but nothing on the technicalities of swapping it. (And there's nothing in the service manual) Any advice you may have would be much appreciated. Cheers. Steve. (Edited for cak spelling) <{POST_SNAPBACK}> i did the one on my s1 you need some good sockets and some penetrateing fluid! fiddly and your nuckles will bleed but other than that its ok! you dont need to take the under tray off either unless you drop the rachet ..... Link to comment Share on other sites More sharing options...
gerags Posted August 9, 2005 Author Share Posted August 9, 2005 Right. I've got an Eliseparts exhaust manifold gasket as I need to replace the old one. Has anyone replaced this before ? How involved is it ? I've searched SELOC and all they say is "it's an easy" and "the gasket was too thin and I needed to fit washers" but nothing on the technicalities of swapping it. (And there's nothing in the service manual) Any advice you may have would be much appreciated. Cheers. Steve. (Edited for cak spelling) <{POST_SNAPBACK}> i did the one on my s1 you need some good sockets and some penetrateing fluid! fiddly and your nuckles will bleed but other than that its ok! you dont need to take the under tray off either unless you drop the rachet ..... <{POST_SNAPBACK}> I may tie a piece of string or elastic to the end of the ratchet - just in case Knowing my luck, though, it'll definitely be needed Link to comment Share on other sites More sharing options...
Martin R Posted August 9, 2005 Share Posted August 9, 2005 Steve, you know where i am if you need a hand. Link to comment Share on other sites More sharing options...
gerags Posted August 10, 2005 Author Share Posted August 10, 2005 Steve, you know where i am if you need a hand. <{POST_SNAPBACK}> Cheers mate. You have a PM. Link to comment Share on other sites More sharing options...
