SOUPS Posted July 18, 2005 Share Posted July 18, 2005 Not sure whats up with lizzy. the keys go in all the way but doenst turn its kind of locked... same thing also happened today to my other car (Rover) they both have rover parts.. any ideas? Link to comment Share on other sites More sharing options...
malbon Posted July 18, 2005 Share Posted July 18, 2005 you mean the key barrel isn't allowing to turn ? Link to comment Share on other sites More sharing options...
SOUPS Posted July 18, 2005 Author Share Posted July 18, 2005 you mean the key barrel isn't allowing to turn ? <{POST_SNAPBACK}> YUP DOENST WANT TO TURN. same thing now happened to my rover Link to comment Share on other sites More sharing options...
jez_s Posted July 18, 2005 Share Posted July 18, 2005 Silly question, but you are trying the right key in the right lock!! Link to comment Share on other sites More sharing options...
Mark H Posted July 18, 2005 Share Posted July 18, 2005 You do know about the steering lock right? try moving the steering wheel at the same time while the key is in the slot. Link to comment Share on other sites More sharing options...
malbon Posted July 18, 2005 Share Posted July 18, 2005 You do know about the steering lock right? try moving the steering wheel at the same time while the key is in the slot. <{POST_SNAPBACK}> like beefcake says. if not - flat head ! Link to comment Share on other sites More sharing options...
ipanter Posted July 18, 2005 Share Posted July 18, 2005 do you have a heavy bunch of keys on your key ring? if so the constant swinging of them whilst moving causes the barrel or key (whichever is softer) to wear, if this is the case try your spare key and hope that it is the key that is softer. Link to comment Share on other sites More sharing options...
SOUPS Posted July 19, 2005 Author Share Posted July 19, 2005 do you have a heavy bunch of keys on your key ring? if so the constant swinging of them whilst moving causes the barrel or key (whichever is softer) to wear, if this is the case try your spare key and hope that it is the key that is softer. <{POST_SNAPBACK}> just got one key not a bunch. i think the lock is knackered Link to comment Share on other sites More sharing options...
GCCK Posted July 19, 2005 Share Posted July 19, 2005 The Elise key is a Vauxhall part. Does that mean the lock would be, also? Link to comment Share on other sites More sharing options...
Reg Posted July 19, 2005 Share Posted July 19, 2005 The Elise key is a Vauxhall part. Does that mean the lock would be, also? <{POST_SNAPBACK}> Yes, the lock will be a Vauxhall part. Use a squirt of WD40, or similar in the lock. Reg - Master Locksmith Link to comment Share on other sites More sharing options...
