Bramble111s Posted April 5, 2005 Share Posted April 5, 2005 Just been quote 58squid or so to replace cable and handle, my cable is very stiff and the handle rod is very rusty. I assume its cheaper to replace before it breaks? Am I missing a trick on this, as I have read ages ago about peeps doing it themselves, only I think I read it was a clam off job and a bit damn tricky? Any advise please? thanks in advance (i Hope! ) Link to comment Share on other sites More sharing options...
Scott_Mac Posted April 5, 2005 Share Posted April 5, 2005 £58 seems fair... its a pig of a job, not clam off, but you do have to take half the interior to pieces to get at the bits (i.e. speaker pods out etc) I'd pay the £58 Link to comment Share on other sites More sharing options...
Bramble111s Posted April 7, 2005 Author Share Posted April 7, 2005 okey dokey thanks Link to comment Share on other sites More sharing options...
seanster Posted April 7, 2005 Share Posted April 7, 2005 Better to do it before it breaks, pain to open the boot otherwise!! To buy the cable is about 30quid+ so 25 on top to fit is not bad and yes it really is a pig of a job unless you have very small hands. Link to comment Share on other sites More sharing options...
dobbo Posted April 7, 2005 Share Posted April 7, 2005 IIRC, £8 cable from Peter Smiths (Yes, really) and I fitted it myself without clam off. Admittedly I didn't bother with one of the grommets, but I also didn't need to remove the speaker, wheel arch liner. A couple of years ago, so it's a bit hazy, but it is DIY if you want it to be. Depends how much you value the other £50 Link to comment Share on other sites More sharing options...
MarkH Posted April 9, 2005 Share Posted April 9, 2005 Took me half a day to do mine - so £50 sounds pretty good! Wheel arch liners should come off, speaker panels & then it's pretty simple. Good instructions available on the web - elisenet.com. Mark Link to comment Share on other sites More sharing options...
Dixie Posted April 12, 2005 Share Posted April 12, 2005 Bit awkward. Not to bad though. Take the speaker pod thing out, undo the nut at the back of the cable. Pull the cable out (towards the front of the car) Snip the end off with some decent snips. TAPE the end of the old cable to the BOOT END of the new one. Make sure you use some really good tape. Duck tape is best i think. Also make sure it's only 1 wrap as the tape needs to fit through the nut that you just undid. Once the 2 cables are stuck together, carfully pull the old one out from the boot end. Take care not to pull the old nutthrough with the cable. Hey presto the new one is in! Just connect it to the release mechanism and put the nut back on the handle end. Link to comment Share on other sites More sharing options...
Bramble111s Posted April 12, 2005 Author Share Posted April 12, 2005 Hmm, cheers all, will probally go the mechanic route, although it does sound kinda straight forward. What about future proofing? As my pull handle part has gone rusty within a year, I guess it needs more lovin' How do people care for this part? Link to comment Share on other sites More sharing options...
Scott_Mac Posted April 12, 2005 Share Posted April 12, 2005 Latest part from Lotus is inside a plastic sheath... seems a lot better. Link to comment Share on other sites More sharing options...
