ALCHBY Posted February 22, 2005 Share Posted February 22, 2005 Noticed my Recently Purchased Lotus has Koni Suspension (Gas Filled) is this standard ? If it's not how do i check if it's Adjustable. Al Link to comment Share on other sites More sharing options...
Scott_Mac Posted February 22, 2005 Share Posted February 22, 2005 Std dampers are Red coloured, they are not adjustable. Uprated (LSS) are yellow and are adjustable for height only. Some folks have fitted other Koni dampers... you'd have to check with the manufacturer for the specs on those. Link to comment Share on other sites More sharing options...
juicetin Posted February 22, 2005 Share Posted February 22, 2005 You can of course adjust the height slightly on the standard koni dampers by adjusting the spring circlip position, they are automatically set to the highest ride height by the factory. Link to comment Share on other sites More sharing options...
ALCHBY Posted February 22, 2005 Author Share Posted February 22, 2005 You can of course adjust the height slightly on the standard koni dampers by adjusting the spring circlip position, they are automatically set to the highest ride height by the factory. <{POST_SNAPBACK}> How much will it drop? Will it affect the car in anyway is it easy to do Link to comment Share on other sites More sharing options...
dss123 Posted February 22, 2005 Share Posted February 22, 2005 Al, Not sure with standard Konis, but when fitting LSS (and lowering) you need to relocate the steering rack (with new adaptor plates) to avoid bump steer issues. Dunc Link to comment Share on other sites More sharing options...
Ladders Posted February 22, 2005 Share Posted February 22, 2005 Dont think I'd be to happy moving the circlips on the suspension! Not worth weakening them IMO! I'd think about S2 susp for £520 if your that bothered about changing the susp Link to comment Share on other sites More sharing options...
juicetin Posted February 23, 2005 Share Posted February 23, 2005 Why does moving the spring circlip weaken the shock absorber ? There are fixed grooves where the spring height can be set. They are set to the heighest ride height by the factory, moving the clip to the lowest position would lower the ride height by circa 1-2cm. Link to comment Share on other sites More sharing options...
Ladders Posted February 23, 2005 Share Posted February 23, 2005 No, weakening the circlip! Link to comment Share on other sites More sharing options...
Zircon450 Posted February 23, 2005 Share Posted February 23, 2005 Is this why early STD S1's are 140mm and later S1's STD 160mm ride height ? Link to comment Share on other sites More sharing options...
GCCK Posted February 24, 2005 Share Posted February 24, 2005 Early S1's at 140/140 had straight, parallel springs. Later ones had slightly barrelled springs. Theoretically a barrel shaped spring should provide slightly more progressive behaviour and lower noise. Quite why it was felt necessary to change the springs, and in turn change the ride height, I've no idea. Link to comment Share on other sites More sharing options...
Martin R Posted February 24, 2005 Share Posted February 24, 2005 Apparently they changed the springs because on the early ones the springs and dampers could touch and cause a noise. The barrel ones cant do this apparently. Link to comment Share on other sites More sharing options...
