Mark H Posted January 26, 2010 Share Posted January 26, 2010 Vented brake discs are standard with cross-drilled brake discs forming part of the Sport Pack, (both are massive 350 mm diameter discs on the front and 332 mm diameter at the rear), which when combined with high performance bespoke Lotus AP Racing 4 pot callipers ensure impressive stopping power.Everyone connected with the brake testing programme, conducted on the punishing corners, climbs and descents of the Nürburgring and Stelvio Pass, has described the brakes as ‘phenomenal’ with excellent thermal performance and outstanding feel even after extended sessions of extreme use. Part of that testing programme was to finalise settings for the ABS system being developed in conjunction with Bosch. The system is tuned for performance driving and thus has very high thresholds and operates so progressively that drivers are often unaware that they have actually triggered the ABS. Hydraulic Brake Assist (HBA) and Electronic Brake Distribution (EBD) are also fitted as standard. HBA detects an emergency braking situation and increases brake pressure up to ABS activation threshold which results in shorter emergency stopping distances. Related images are here: http://www.midlandslotus.co.uk/forum/index...=sc&cat=178 This post has been promoted to an article Link to comment Share on other sites More sharing options...
