Mark H Posted January 26, 2010 Share Posted January 26, 2010 Lotus Evora – Safety SystemsIn common with the Elise and its derivatives, the Evora’s bonded extruded aluminium chassis tub has incredible inherent strength, particularly in regard to front and side impacts. Additional torsional strength is given to the whole structure by the tubular steel seatbelt anchorage frame. Deformable, sacrificial aluminium front and steel rear subframe modules are attached to the tub using joints which are designed to minimise damage to the tub, protecting the main passenger cell in the event of an accident. Driver and passenger airbags are standard as are pyrotechnic seat belts for the front two occupants. The airbag on the passenger side is cleverly engineered to deploy vertically and then be deflected rearwards by the windscreen, to provide protection. Anti-lock brakes are standard on all models, as is Lotus Traction Control (LTC); these systems have been specially developed as a collaboration between Lotus and Bosch engineers and enable drivers to consistently exploit the braking and performance capabilities of the Evora, whilst allowing skilled enthusiasts the freedom to enjoy the full Lotus driving experience. The Switchable Lotus Traction Control (LTC) system has been developed simultaneously with the ABS and works through the engine management system to reduce power to the rear wheels when required to maintain traction. To maintain front end traction or to reduce understeer, the LTC will gently reduce engine torque to stabilise the Evora bringing the front wheels back into line – known as “Understeer Recognition”. Unlike many traction control systems, LTC has been tuned to complement the skills of the driver without taking over. The Lotus LTC is active above 5 mph (8 km/h) and operates much more quickly than many brake based systems. The system can be deactivated completely, giving no traction control intervention. A Bosch Electronic Differential Lock (EDL) is fitted as standard to the Lotus Evora. This advanced technology controls the speed of individual rear wheels through the precise activation of the rear brakes, slowing an excessively spinning rear wheel to ensure that traction is maintained without causing detriment to the handling – often the case with a mechanical limited slip differential. Hydraulic Brake Assist (HBA) and Electronic Brake Distribution (EBD) are also fitted as standard. HBA detects an emergency braking situation and increases brake pressure up to ABS activation threshold which results in shorter emergency stopping distances. As with all Lotus cars, the Evora is very driver focussed and therefore all the electronic intervention systems can be completely overridden by the driver (apart from the ABS). In standard mode, all the systems above are in operation; pressing the sport button (Sport Pack option only) sharpens the throttle response and increases the engine rev limit. The sports mode traction control is adjusted to give increased slip and yaw angle before intervening, and also removes the understeer recognition. Lotus Evora: 205 g/km CO2 8.7 litres / 100 km (32.5 mpg) Combined Cycle 12.4 litres / 100 km (22.8 mpg) Urban Cycle 6.5 litres / 100 km (43.5 mpg) Extra Urban Cycle Related images are here: http://www.midlandslotus.co.uk/forum/index...=sc&cat=178 This post has been promoted to an article 20100126_190720.198.71.pdf Link to comment Share on other sites More sharing options...
