Mark H Posted January 26, 2010 Share Posted January 26, 2010 Lotus Evora - Technical SpecificationsHeadline figures Max Power 280PS @ 6400 rpm C02 emissions 205 g/km Weight 1382 kg 0-60 mph 4.9 seconds 0-100 km/h 5.1 seconds Top speed 162 mph /261 km/h Fuel economy 32.5 mpg - 8.7 l/100km (combined cycle) Vehicle Description Technical Specifications Engine Mid-mounted, transverse, 3456 cc, DOHC Dual VVTi Engine management Lotus T6e engine control unit Swept volume (Bore x Stroke) 94 x 83 mm Compression ratio 10:1 Max Power 280PS/ 206 kW/ 276 hp @ 6400 rpm Max Torque 350Nm/ 258 lbft @ 4700rpm Specific power output (PS/ litre) 81 Cylinder head material Aluminium Engine block material Aluminium Number of crankshaft bearings 4 Number of camshafts 4 Fuel supply system Returnless Fuel injection Idle running speed 600-680 rpm (variable) Ignition 1 spark plug per cylinder Steering Lotus tuned power steering Turn radius 10.14 m Steering lock to lock 2.86 Service interval 9000 miles Warranty 3 year 100,000km (60,000 miles) whole vehicle warranty with 8 years chassis perforation warranty for EU markets Fuel Petrol 95 RON Performance Figures Maximum speed 162 mph Maximum speed 261 km/h 0-60 mph 4.9 seconds 0-100 mph 12.3 seconds 0-100 km/h 5.1 seconds 0-160 km/h 12.2 seconds 60-0 mph 33.6 meters – 2.4 seconds 100-0 mph 88.6 meters – 3.9 seconds 100-0 km/h 36.8 meters – 2.5 seconds 160-0 km/h 89.5 meters – 3.9 seconds Transmission Gearbox 6 speed manual Clutch Single plate Differential Open type Transmission ratio Sports Standard 1st 3.538 3.538 2nd 1.913 1.913 3rd 1.407 1.218 4th 1.091 0.86 5th 0.9697 0.79 6th 0.8611 0.638 Reverse gear 3.831 3.831 Final drive 1st - 4th 3.777 3.777 Final drive 5th- 6th 3.238 3.238 Emissions Emissions Euro 4 compliant C02 emissions 205 g/km Fuel economy Combined 32.5 mpg – 8.7 litres / 100km Fuel economy Urban 22.8 mpg – 12.4 litres / 100km Fuel economy Extra Urban 43.5 mpg – 6.5 litres / 100km Fuel tank capacity 60 litres usable volume Fuel system Stainless steel fuel tank with Onboard Refuelling Vapour Recovery to capture hydro-carbon vapour given off during refuelling Exterior Dimensions Overhang Front 993 mm Overhang Rear 774 mm Ground clearance 120 mm Overall length 4342 mm Overall height - 1223 mm Overall width 1848 mm Wheelbase 2575 mm Track Front at ground 1567 mm Track Rear at ground 1575 mm Design front ground clearance 125 mm Design rear ground clearance 147 mm Chassis Power to weight (PS/ 1000 kg) 203 Chassis Lotus designed VVA (modular lightweight bonded Aluminium structure) Vehicle torsional stiffness 26 600 Nm per degree Front suspension Double wishbone suspension, antiroll bar, Eibach springs and Bilstein dampers Rear suspension Double wishbone suspension, antiroll bar, Eibach springs and Bilstein dampers Wheels Cast wheels - Silver or Stealth Grey (option) – 18” x 8” front & 19” x 9.5” rear Forged wheels (option) –Silver or Anthracite – 18” x 8” front & 19” x 9.5” rear - (3.2 kg lighter) Front tyres 225/40 ZR18 Pirelli P-Zero Rear tyres 255/35 ZR19 Pirelli P-Zero Total chassis weight 206 kg Front module 25 kg Rear module 58 kg Chassis tub 100 kg Seatbelt anchorage frame 23 kg Weight distribution 39% Front - 61% Rear GVW 1782 kg Vehicle mass 1382 kg Brakes Operation Servo assisted brakes Anti lock brakes Lotus tuned Bosch ABS system Brake technology Hydraulic Brake Assist, Electronic Differential Lock and Electronic Brake Distribution Brake calipers AP-Racing four-piston calipers (front and rear) Front discs 350 mm ventilated (cross drilled optional) Rear discs 332 mm ventilated (cross drilled optional) Hand brake Drum in hat Aero Drag (Cd) 0.33 Drag (Cd.A) 0.627 Front downforce 3 kg at 100 mph (160 km/h) Rear downforce 5 kg at 100 mph (160 km/h) Aero package features Rear diffuser, splitter, flat underbody and floating rear wing Related images are here: http://www.midlandslotus.co.uk/forum/index...=sc&cat=178 This post has been promoted to an article 20100126_191215.199.413.pdf Link to comment Share on other sites More sharing options...
