Martin R Posted September 22, 2008 Share Posted September 22, 2008 Bob, here we go. First pic is of the inlet manifold with the plenum removed ( and on my bench ) Second pic is of the water pipe connection Now a couple of pics of the gasket after i removed the manifold The first one is the reverse of the water pipe connection. You can just see the jiggle valve in the casting. The manifold is held on by a couple of studs and nuts at the top and about 6 or 7 set pins underneath. The nuts are 13mm heads and the pins 10mm heads.To remove them i used a 3/8 drive socket set with a couple of extension bars. You will also need a knuckle joint to aid access. Ive no idea what the blue residue is on the gasket. I also cant see any o ring. Im either loosing the plot or imagining things in my old age. I will have a search later for the thread that mention it. A final though. The fuel rail also holds a fair bit of fuel even when you have drained the system as i did. If you are not careful it will go all over you slippers Im in for a bollocking no doubt. Bob, here you go. 5th post down on this thread by DVA. No idea what he is on about. Something else i will have to ask him. Im glad ive not lost the plot yet http://forums.seloc.org/viewthread.php?tid...ge=1#pid3509109 Edit, having had another think DVA is probably on about the o ring on the sensor on the manifold. Its the oxygen sensor i presume. I thought there would be a o ring on the inside of the water pipe conection between the head and manifold. My mistake HTH. Link to comment Share on other sites More sharing options...
Tango190 Posted September 29, 2008 Share Posted September 29, 2008 Wanna come take a nosey at mine Martin, beer , Curry stop over lol I am so lost on it now, the symptoms still seem electrical misfire and laptop tells me misfire sure this cam up a long time ago about muliple misfire on K series I know a leak is ther on coolant, but only from cold - seems odd PM for Dinner - lol About time we saw you anyway ... Link to comment Share on other sites More sharing options...
kimbo Posted September 30, 2008 Share Posted September 30, 2008 A final thought. The fuel rail also holds a fair bit of fuel even when you have drained the system as i did. If you are not careful it will go all over you slippers Im in for a bollocking no doubt. Link to comment Share on other sites More sharing options...
Martin R Posted October 1, 2008 Share Posted October 1, 2008 Wanna come take a nosey at mine Martin, beer , Curry stop over lol I am so lost on it now, the symptoms still seem electrical misfire and laptop tells me misfire sure this cam up a long time ago about muliple misfire on K series I know a leak is ther on coolant, but only from cold - seems odd PM for Dinner - lol About time we saw you anyway ... Sorry Bob , ive only just spotted this. I will PM you later. Kim you are so right Link to comment Share on other sites More sharing options...
Tango190 Posted October 7, 2008 Share Posted October 7, 2008 Hey guess what Martin - since we looked at this at the weekend ... Still loosing coolant, but .... Filled up with fuel to the brim - added an injector cleaner .... Now for 2 days it's started fine ??? Still has slight misfire that even the best mechanic would not spot .... Power is still slightly less than expected ... Am CONVINCED that that the little pipe on the inlet manifold is pissing into cylinder 1 as your gasket explained. Gonna have to rip that lot off and change it, is really bugging me now. Where can I source the inlet manifold gasket ?? Link to comment Share on other sites More sharing options...
Martin R Posted October 7, 2008 Share Posted October 7, 2008 Bob, elise parts do individual gaskets for the k HTH Here you go http://www.eliseparts.com/shop/index.php?m...products_id=569 You may have to ring them Bob. Im not sure if its # 16 Link to comment Share on other sites More sharing options...
Tango190 Posted October 8, 2008 Share Posted October 8, 2008 Bob, elise parts do individual gaskets for the k HTH Here you go http://www.eliseparts.com/shop/index.php?m...products_id=569 You may have to ring them Bob. Im not sure if its # 16 Ta Martin Pity they dont fit them too - LOL Link to comment Share on other sites More sharing options...
