janemadasafish Posted August 26, 2004 Share Posted August 26, 2004 Just received horrific quote to replace ball joints and alternator at Lotus dealer. Anybody know where you can source Lotus parts other than from a rip off dealer? Have tried eurocarparts - they don't do Lotus Link to comment Share on other sites More sharing options...
tazbaz69 Posted August 26, 2004 Share Posted August 26, 2004 try eliseparts.com, or rover, they sometimes tend to be cheaper than lotus.........or ask euro parts to supply u with a rover 25/75 alterantor, i bet it is exactly the same part as lotus use. Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 26, 2004 Share Posted August 26, 2004 Ball Joints are a common part - try Partco or similar, Horizon repalced mine at service, and they got them from there. Alternator is only about £50 - £60 IIRC Link to comment Share on other sites More sharing options...
Mark H Posted August 26, 2004 Share Posted August 26, 2004 or ask euro parts to supply u with a rover 25/75 alterantor, i bet it is exactly the same part as lotus use. Probably not worth the risk on that unless you can be sure. Partco would be a safer bet and get the correct part instead. Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 26, 2004 Share Posted August 26, 2004 Apparantly the alternator in the S1 is the same as that used in the MGF VVC <spit> (not the same as std MGF/200/400) Not sure if its the same for S2 though. Link to comment Share on other sites More sharing options...
tazbaz69 Posted August 26, 2004 Share Posted August 26, 2004 Probably not worth the risk on that unless you can be sure. Partco would be a safer bet and get the correct part instead. get part number from the alternator, when i rebuilt my cylinder head after HGF i used rover to buy my parts, ie cam belt, water pump, rocker cover gasket. u,ll be suprised that all th parts are made for rover, sent to lotus who put on there charge. the 1.8 k series was used in 25/75 and host of other rovers. just take ur old parts to rover and match them at lower price Link to comment Share on other sites More sharing options...
Bramble111s Posted August 26, 2004 Share Posted August 26, 2004 Whilst we are on Ball joints, I am due these by next service... Is it a BIG job, as the quote certainly is!? Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 26, 2004 Share Posted August 26, 2004 Steering rack has to be dropped etc... so yes big job, right PITA! Horizon charged me about £100 all in IIRC... (not 100% sure on that) Link to comment Share on other sites More sharing options...
Mark H Posted August 26, 2004 Share Posted August 26, 2004 get part number from the alternator, when i rebuilt my cylinder head after HGF i used rover to buy my parts, ie cam belt, water pump, rocker cover gasket. u,ll be suprised that all th parts are made for rover, sent to lotus who put on there charge. the 1.8 k series was used in 25/75 and host of other rovers. just take ur old parts to rover and match them at lower price Thats fine, like I said as long as your sure, if you know the part number and they match it then fine not worth the risk for a burnt out car if you dont have that info. Link to comment Share on other sites More sharing options...
janemadasafish Posted August 26, 2004 Author Share Posted August 26, 2004 Ball Joints are a common part - try Partco or similar, Horizon repalced mine at service, and they got them from there. Alternator is only about £50 - £60 IIRC Thanks Scott - found Partco on internet but can't find Horizon - are they are garage or parts supplier. what does IIRC mean? !! To everybody else who has responded, thanks very much, you've given my credit card hope! Link to comment Share on other sites More sharing options...
Fiona Posted August 26, 2004 Share Posted August 26, 2004 http://www.horizonmotorsport.co.uk/ IIRC - if I remember correctly. Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 26, 2004 Share Posted August 26, 2004 Without even moving my lips (typing on my keyboard) Thanks PA Link to comment Share on other sites More sharing options...
janemadasafish Posted August 26, 2004 Author Share Posted August 26, 2004 http://www.horizonmotorsport.co.uk/ IIRC - if I remember correctly. Cheers Fiona Link to comment Share on other sites More sharing options...
enxrjm Posted August 26, 2004 Share Posted August 26, 2004 Jst FYI, the ball joints part number is : QH part number - QSJ883S - as found on the British Cars BBS - can be ordered cheaply form any motorfactor Link to comment Share on other sites More sharing options...
