jaye.tillson Posted July 31, 2004 Share Posted July 31, 2004 I have a rattle that I havent been able to identify for weeks. I just assumed it was the rollover bar but having spent a LONG time in the car today I finally decided I had to do some testing when I got home. It turns out that it is not the roll bar or back window (does it when both are OUT). It is definately coming from the drivers side so can only assume that it is either the drivers door (rattle is still there with window UP and DOWN) or the seat (rattles is still there with seat in all positions). I also have a CD changed behind the seats that may need to be tightened but if after I do that it still rattles does anyone have any ideas what it could be? Thanks Jaye Link to comment Share on other sites More sharing options...
Kris H Posted August 1, 2004 Share Posted August 1, 2004 I have similar in mine and I'm pretty sure it's to do with the door pins. Not quite sure how to check though, and the door isn't flying open, and only really happens on bumpier roads. I have an S2 though so it could be a completely different cause. Also worth checking windows? Link to comment Share on other sites More sharing options...
Dixie Posted August 1, 2004 Share Posted August 1, 2004 Could be the coolant pipes inside the chassis lag? Link to comment Share on other sites More sharing options...
JohnnyM Posted August 1, 2004 Share Posted August 1, 2004 on mine if you push the allen key for the roof into its hole too far it rattles againt the chassis Link to comment Share on other sites More sharing options...
jaye.tillson Posted August 2, 2004 Author Share Posted August 2, 2004 I will try both of those and see how it goes. Jaye Link to comment Share on other sites More sharing options...
jaye.tillson Posted August 2, 2004 Author Share Posted August 2, 2004 Ok, its not the allen key. It seems to be coming from the door. I have the alloy door pins. Anyone know how to get them out? I guess a funny little alan key, but how do I get the door handle off? Jaye Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 2, 2004 Share Posted August 2, 2004 Depends on your door handle.... mine has 4 small allen key bolts holding a cover on, then one bolt behind it. Link to comment Share on other sites More sharing options...
ally Posted August 2, 2004 Share Posted August 2, 2004 I have an S1 and mine had been rattling for a while too. On mine the brackets gripping the window had come loose so the glass was knocking on the inside of the door. There is a thread on this (just type in windows on the MLOC search) with farely extensive instructions about getting into the door pannel. It reccomneded an industrial glue, I just used arildite and touch wood it has worked really well. Ally Link to comment Share on other sites More sharing options...
jaye.tillson Posted August 3, 2004 Author Share Posted August 3, 2004 Ok, last night i got out the allen keys and played around with the door pins. Today I drove the car and the rattling is a lot less. This could be due to the weather not being so hot, or I might have figured out the problem! Wish me luck! jaye Link to comment Share on other sites More sharing options...
ally Posted August 3, 2004 Share Posted August 3, 2004 Well if it hot weather thats the problem you shouldnt need to worry about getting the problem much Link to comment Share on other sites More sharing options...
Maldives Posted August 3, 2004 Share Posted August 3, 2004 This is not the solution to your problem but it might be of interest . I have had a rattle for some time which I now beleave to be the CAT converter loose in its housing, particularly when hot. Link to comment Share on other sites More sharing options...
jaye.tillson Posted August 3, 2004 Author Share Posted August 3, 2004 I had the cat rattling at one point. So I removed it I am almost 100% sure its the door now tho. Having tightended everything else! Jaye Link to comment Share on other sites More sharing options...
Scott_Mac Posted August 3, 2004 Share Posted August 3, 2004 Remove that too then. Should solve your problem Link to comment Share on other sites More sharing options...
jaye.tillson Posted August 6, 2004 Author Share Posted August 6, 2004 Gave the car a good thrashing today whilst working from home and the noise is still very much there. It is coming from towards the front of the door. I have tightened all the doors pins and nothing. Is the collant pipe inside the drivers rail? Jaye Link to comment Share on other sites More sharing options...
