Ruxpin Posted March 4, 2004 Share Posted March 4, 2004 Was out last weekend and the speedo was jumping all over the place, + and - 25mph to what i would guess was the true reading. Initially i thought it only happened when going over bumps but seemed to be doing it on smooth roads too. At motorway speeds it seemed to settle down, but on slowing down it was still all over the place. Any one else had this problem? Suggestions / ideas would be helpfull, cheers, Rich Link to comment Share on other sites More sharing options...
Bramble111s Posted March 4, 2004 Share Posted March 4, 2004 Had exactly the same thing with my rev counter. reading zero and then flickering all over the shop. Apparently sometimes a bug in the system can cause this and after one turns off the engine it will probally reset?!?!?!?!?!?! Or so the lotus dealer told me. Worst case is a sensor error. My rev counter is now normal, so guess it seems true enough. If problems persist suggust you get the sensor looked at? Link to comment Share on other sites More sharing options...
MarkR Posted March 4, 2004 Share Posted March 4, 2004 Rich I experienced something similar on both the Rev counter & speedo. Nick Whale said it would reset which it did but only to persist again and again. Unit finally returned to Stack who couldn't find anything wrong but replaced it with new item at cost. Been OK since. Mark Link to comment Share on other sites More sharing options...
JohnnyM Posted March 4, 2004 Share Posted March 4, 2004 try re-seating the cable on the sensor on the N/S rear wheel, worked for me. Johnny M Link to comment Share on other sites More sharing options...
Ruxpin Posted March 5, 2004 Author Share Posted March 5, 2004 Cheers for the advice guys, will have a play at the weekend......not long now Link to comment Share on other sites More sharing options...
