Overview
There are numerous options of springs and dampers (commonly referred to as suspension options) available for Elises. Some of these are available from the factory (such as the red Konis fitted to std S1's, the yellow Lotus Sport Suspension dampers fitted on higher spec variants and the yellow Bilsteins fitted to S2's) and some are from specialist aftermarket manufacturers (e.g. Nitron, Spax, Gaz etc).
The spring and damper perform different operations; the spring is there predominantly to support the mass of the car whilst the damper resists movement - the faster the suspension moves the more the damper resists.
Most car damper units are single piece and unadjustable, thats to say that the settings are fixed. Obviously this is then a compromise between useage, e.g. smooth racetracks and potholed roads. Higher spec dampers offer adjustment via one or more knobs somewhere on the damper. The adjustments affect the bump and rebound characteristics of the unit. Bump is the resistance to movement as the damper is compressed, e.g. over bumps and racetrack kerbs, whilst rebound is the resistance to the damper uncompressing, usually after a bump. These settings are usually adjusted via knobs or screw adjusters somewhere on the damper. The number of adjusters depends on the type of damper; '1 way', '2 way', '3 way' etc.
  • '1 way' units have a single adjuster that adjusts both bump and rebound together
  • '2 way' units have individual adjusters for bump and rebound
  • '3 way' units have individual adjusters for low speed bump movement (e.g. 'normal' road undulations), high speed bump movement (e.g. kerb strike etc) and rebound.
The more complex units units also come in a selection of appearences, with an extra cylinder either 'piggy backed' on the main unit or remotely mounted on a hose.
Finally, standard road dampers have fixed spring positions, whereas higher spec dampers have moveable platforms that allow rideheights to be adjusted.
1-way adjustable, single piece dampers with adjustable platforms are the most common choice in higher spec aftermarket dampers and a good cost/performance compromise for road and trackday use. The best combination of spring, damper (make and setting) and ride height depend on useage and driver preference, although there is a lot of advice to be had on the forums.
Bilsteins
Advantages
  • 1 Relativly Cheap
  • 2 Good Peformance for the Money
  • 3 Good Ride Quality
  • 4 Better than the OE fit Koni's
  • 5 Can be set to adjust the ride height
  • 6 Don't have to be declared as a Mod to insurance companies
Disadvantages
  • 1 A bit soft for hardcore track work
  • 2
  • 3
Koni
Advantages
  • 1
  • 2
  • 3
Disadvantages
  • 1
  • 2
  • 3
Nitron
Advantages
  • 1 Some of the best suspension you can get for the Elise
  • 2
  • 3
Disadvantages
  • 1 Expensive
  • 2
  • 3
Ohlins
Advantages
  • 2
  • 3
Disadvantages
  • 1 Expensive
  • 2
  • 3
To get you started, here are a few settings to try (all counted from "full hard")...
Gentle road / wet: -24, -28 Motorway: -20, -25 Fast road (runs): -18, -22 Dry track cold: -13, -18 Dry track hot: - 8, -12 Wet track: -15, -18
... although obviously experiment with what suits your driving. In short, for slower & bumpier, the softer it has to be.
You can adjust the front-rear bias usefully (relative settings). For damp and/or gusty conditions, soften the front more and it increases "feel" and stability - in effect dialling in a fraction more understeer which is a good for safety in such conditions. Then harden the front for more neutral handling, in effect maximising rear grip for when you can be more brutal with the power through the back wheels.
Although there are allegedly 60 clicks on an Ohlins tube, forget about the softest 30 - it makes the car too bouncy.
Gaz
Advantages
  • 1 Cheap
  • 2
  • 3
Disadvantages
  • 1 Not good on Elises
  • 2
  • 3
Avo
AVO fully adjustable shock and spring kit, adjustable damping rate, adjustable ride height platforms.
Advantages
  • 1 Cheap
  • 2
  • 3
<a name="Disadvantages_6" id="Disadvantages_6">
Disadvantages
  • 1 Sound for a budget shock, standard road setting they are fine.
  • 2 As the old adage goes, you get what you pay for
  • 3
User Feedback
  • VIEWING
    Can I get peoples thoughts on this  my lack of knowledge on models I thought this car would have had the Rover engine  its a 2010 1.8S but has a supercharger fitted producing 218bhp cant seem to paste the link but looks a stunning car
    Timsrs
    Timsrs
    Technical Talk 2
    Lotus in the Peak Digital info Files
    Please find Digital LitP info below.  Please ensure you are logged into the MLOC forum and then click this link:  Note there Are No Physical Tickets Please print off any of the info contained as you feel necessary. There are:- Map links for the run locations. GPX files. Your final instructions. A full runs group list - please note your group number and leader's name. A copy of the Safety Brief. Important - If you are taking part in a Sunday m
    Elisemadray
    Elisemadray
    General Talk 6
    Lotus in the Peak info
    Hi all that have booked for this years LitP all final info will be emailed out Thurs/Fri please check your spam thanks the LitP team
    Elisemadray
    Elisemadray
    General Talk 4
    Formula One
    Maddox
    Maddox
    General Talk 4
    School prom 21st June help
    Can anyone with an unusual Lotus help me out this Saturday 21st about 6pm in south Derbyshire. So my lad has his school leaving prom this Saturday, some of you will have met Jasper helping out with the parking or sound system at past LITP’s.  As I take Jasper to school in my Evora everyday he doesn’t think it’s special, so I sorted that his friend is going to go in my Evora and I was borrowing my mate Wayne’s S1 Exige to take him as something a bit different .  Unfortunately Wayne’s S1 has
    chris_h
    chris_h
    General Talk 7
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,439
    Total Members
    1,800
    Most Online
    jimmy_c
    Newest Member
    jimmy_c
    Joined
