Was scared to do this myself, In a moment of boredom I took the risk... It's actually really simple 5min job...
1. Boil the kettle, poor the boiling water into a bowl, add washing liquid - make bubbly
2. Wet the area around the badge keep applying the hot water to heat to the top of the badge
3. Gently use a flat edged ruler, slowly slide under the badge, applying more hot water, mover the ruler evenly around under the badge until you hit the pins (which aren't screwed in), adding more soapy water to lift the adhesive and slightly lifting carefully, eventually it will pop off.
4. Apply your new badge - job done
Just make sure your delicate with the ruler and don't be too heavy handed, anyone can do it - simples!
User Feedback
  • Lotus in the Peak
    Hi. I’ve not received my pack yet for for Sundays LITP. Has everyone else received there’s yet or am I worrying unduly ?
    Vince Licata
    Vince Licata
    General Talk 1
    VIEWING
    Can I get peoples thoughts on this  my lack of knowledge on models I thought this car would have had the Rover engine  its a 2010 1.8S but has a supercharger fitted producing 218bhp cant seem to paste the link but looks a stunning car
    Timsrs
    Timsrs
    Technical Talk 2
    Lotus in the Peak Digital info Files
    Please find Digital LitP info below.  Please ensure you are logged into the MLOC forum and then click this link:  Note there Are No Physical Tickets Please print off any of the info contained as you feel necessary. There are:- Map links for the run locations. GPX files. Your final instructions. A full runs group list - please note your group number and leader's name. A copy of the Safety Brief. Important - If you are taking part in a Sunday m
    Elisemadray
    Elisemadray
    General Talk 6
    Lotus in the Peak info
    Hi all that have booked for this years LitP all final info will be emailed out Thurs/Fri please check your spam thanks the LitP team
    Elisemadray
    Elisemadray
    General Talk 4
    Formula One
    Maddox
    Maddox
    General Talk 4
  • MLOC classifieds
  • MLOC garage
  • Member Statistics
    4,439
    Total Members
    1,800
    Most Online
    jimmy_c
    Newest Member
    jimmy_c
    Joined
