Red Devil Posted February 10, 2004 Share Posted February 10, 2004 I have recently picked up my Elise. However it seems to have developed a strange knocking sound when I steer - mainly when I steer left!!?? Is it meant to do this? The steering doesn't seem to be affected but I am a bit concerned as I have only had the car for 2 days. It's a MK2 sport 135 model - done 12000 miles. Many thanks. Steve Link to comment Share on other sites More sharing options...
Simon G Posted February 11, 2004 Share Posted February 11, 2004 Steve, is the knocking coming from the front or back, not always easy to tell? Could be from the rear, in which case it could be your toe link joints have dried up. Both mine were replaced under warrenty on my S2. One in particular dries out as it is next to the cat. You will notice the noise at slower speeds and usually when turning or going up/down a kerb. If it's from the front, then it could be your steering rack, ball joints etc. How many miles has the car done? Link to comment Share on other sites More sharing options...
Simon G Posted February 11, 2004 Share Posted February 11, 2004 Sorry, done 12k miles! If you bought it from a dealer then just take it back. If not then take it to either Nick Whale in Brum or Brooke Kensington in Bicester. Link to comment Share on other sites More sharing options...
strees Posted February 11, 2004 Share Posted February 11, 2004 Possibly the UJ are loose - it is a known problem that the upper and/or lower UJ will loosen over time. A quick tighten will resolve the issue. As you have just bought it (and in any event within 6 months of purchase) I would return it to the garage to sort out Link to comment Share on other sites More sharing options...
Red Devil Posted February 12, 2004 Author Share Posted February 12, 2004 Thanks for the responses. It appears to be getting worse so I have booked it into NW on Sat morning. Hopefully it will be something trivial! Cheers Steve Link to comment Share on other sites More sharing options...
Foley Posted February 12, 2004 Share Posted February 12, 2004 My old car had similar symtoms, turned out to be worn track rod ends and a simple diy replacement, but if it's under warrenty....... Link to comment Share on other sites More sharing options...
