caves Posted June 1, 2015 Author Share Posted June 1, 2015 Cheers, couldn't find that thread oddly I think from reading a similar one I have th m36 rather than m99 meta alarm as when I check on abacus alarm web site they refer to m36 being hard wired back rather than a plug in unit It may be an expensive experiment but I think I need to order a new Immo and get that fitted The fact the Immo seems to prevent starting on first turn of the key points to it I think Link to comment Share on other sites More sharing options...
Thomas Harborne Posted July 17, 2015 Share Posted July 17, 2015 I had this problem, fuse kept blowing, car wouldnt start. Was as if the battery didnt have any juice. Drop tested battery and was fine, but as i was disconnecting i noticed the clamps were corroded and previous owner had over tightened and snapped them. 2 new clamps and a 3 new fuses later the problem is solved. Did you eventually sort your problem? Link to comment Share on other sites More sharing options...
