Quaife 7 Speed Sequential Gearbox
darryl
Hopefully Quaife will produce one for rear engine rear wheel drive Elise/Exige
QBE89G seven-speed sequential in-line gearbox now in production
Quaife Engineering, the renowned automotive high performance transmission specialist, is delighted to announce the production launch of an in-line gearbox featuring seven forward gears – a first for the firm. Called the QBE89G, the seven-speed unit debuted in prototype form at the Autosport show in 2012 and is now in full production, having passed its extensive bench and field testing programme.
The innovative seven-speed layout fulfils market demands from specialist sportscar manufacturers and motorsport customers requiring an in-line sequential transmission with ultra close ratios. This format ideally suits the demands front engined, rear wheel drive cars running small capacity engines with a narrow power band.
Lightweight construction and user adaptability were key criteria during Quaife’s design of the QBE89G, the structure of the transmission is a lightweight alloy two-piece casing that reduces the unit’s overall weight to just 33 kilos. For easy installation into a wide variety of front engined, rear wheel drive machinery, the QBE89G uses a quill type input shaft.
The QBE89G’s seven forward gears boast ultra-close gear ratios, a modular gear cluster and an open face dog design to ensure rapid gearshifts. Quaife’s addition of a pair of interchangeable drop gears within the QBE89G allows users to easily and quickly tailor the overall gearing to suit their needs, for example for fine tuning between racing circuits to optimise top speed or overall acceleration.
From the outset Quaife’s engineers have designed the QBE89G to run with an optional electronic semi-automatic paddle gearchange system to maximise the transmission’s potential. Intermediate gear ratios for the seven speed Quaife QBE89G are as follows:-
1st 2nd 3rd 4th 5th 6th 7th
2.750 2.214 1.800 1.471 1.238 1.043 0.920
The QBE89G’s drop gear ratio is: 1.045:1.
The seven-speed Quaife QBE89G in-line gearbox is on sale now, priced at £5695.00 excluding taxes.
QBE89G
  • Replies 3
Yes we have heard the same.
I'd rather pay extra £4.5K for a 6 or 7 speed sequential box than the extra £1.5K for the IPS unit.
Hopefully Lotus and Quaife can sort out there differences in the not too distant future; it would be good news if the sequential box found its way onto a V6 Exige before the production ramps up too much.
  • 2 months later...
An inline Gearbox is no use in a car with a transverse engine install
What you need is a transverse Gearbox, with a decent torque rating.
www.youtube.com/watch?v=GOCstC4Sceg
