steve Posted December 3, 2003 Share Posted December 3, 2003 I am sure this is a real easy one but now the cold weather is coming my car is a bit "lumpy when its cold. once its heated up it fine. i really noticed it the other day going up a slip road and was trying to accelerate but not much was happening. then all of a sudden it was like a rocket again. any ideas before Lou has a go??? cheers steve Link to comment Share on other sites More sharing options...
strees Posted December 3, 2003 Share Posted December 3, 2003 Is your car parked outside? If so, could be water in the dizzy cap/spark plugs. If so, spray liberally with WD40. Link to comment Share on other sites More sharing options...
steve Posted December 3, 2003 Author Share Posted December 3, 2003 It is parked outside but it happens every day and always gets better when its warm. could it still be water in the dist cap? Link to comment Share on other sites More sharing options...
strees Posted December 3, 2003 Share Posted December 3, 2003 Possibly. Mine did this (and also had a problem accelerating) until the engine had warmed up. I sprayed the HT leads spark plugs and dizzy cap with WD40, which did the trick. Also wondering whether your IACV is dirty or needs resetting, i.e. it is not mixing the fuel/air correctly when cold. Try resetting with the 5 presses of the accelerator trick. Link to comment Share on other sites More sharing options...
steve Posted December 3, 2003 Author Share Posted December 3, 2003 Oops - you lost me there! IACV? 5 presses of the accelerator? I'll do it... but what am i doing???? I'll also give the HT leads and dist cap a spray of WD40 as you suggest. (i understand that one!) thanks steve Link to comment Share on other sites More sharing options...
Bramble111s Posted December 3, 2003 Share Posted December 3, 2003 Since its been cold, sometimes my revs start at a flickering 1000, only after its warmed up do they settle back to the 900 mark. But I would guess this would be a similar problem? I haven't tried hard acceleration, as I am on the commute and would be up the backside of the car in front. This might be the best place to warm up any cold knobs? Is this too far?? Link to comment Share on other sites More sharing options...
Mark H Posted December 3, 2003 Share Posted December 3, 2003 Sounds like damp as strees mentioned. Link to comment Share on other sites More sharing options...
strees Posted December 3, 2003 Share Posted December 3, 2003 Steve, To reset the IACV (Idle Air Control Valve):- 1. Switch ignition on(all lights on dash lit) 2. Make sure immobiliser is not on 3. 5 slow full presses on the accelerator 4. start engine. Some people say to then switch ignition off, but I have always been told to start. I do however believe it is damp related. You can also by ignition sealant spray from Halfords which might do a better job than WD40, but as I already had it in the stable I used WD40 and it worked. Cheers Simon Link to comment Share on other sites More sharing options...
steve Posted December 3, 2003 Author Share Posted December 3, 2003 Thanks for that, i'll give it a try! Steve Link to comment Share on other sites More sharing options...
Bramble111s Posted December 3, 2003 Share Posted December 3, 2003 Steve, Sorry for my unhelpful reply. My car really does flicker in revs, although this would seem like a normal thing to do in the cold? Very interesting to hear about the idle air reset, will be curious to find out if it helps. Link to comment Share on other sites More sharing options...
steve Posted December 5, 2003 Author Share Posted December 5, 2003 I've reset the IACV (ooh, look at me - i know what i'm talking about now! ) but the weather hasnt been so cold recently so i dont know if its had any effect. I'll keep you posted though! Thanks again guys! steve Link to comment Share on other sites More sharing options...
