bermudabob Posted September 3, 2005 Share Posted September 3, 2005 Anyone know of any step by step guides on how to change S1 rear discs & pads? I'm a bit of a mechanical muppet but thought I'd have a go and can't find a guide on doing it. So far only a pad changing guide on Elisenet, which helps a bit... Link to comment Share on other sites More sharing options...
Mark H Posted September 3, 2005 Share Posted September 3, 2005 http://www.elisenet.plus.com/BrakeHoses.htm Step 14 should help Link to comment Share on other sites More sharing options...
bermudabob Posted September 3, 2005 Author Share Posted September 3, 2005 Cheers - just what I needed... Link to comment Share on other sites More sharing options...
maddog Posted September 3, 2005 Share Posted September 3, 2005 Cheers - just what I needed... <{POST_SNAPBACK}> dont forget you need to screw in the rear calliper piston before you change the pads, you can't push it in like a standard calliper (use a pair of long noise pliers to screw it in) hope this helps Link to comment Share on other sites More sharing options...
