tonner_notts Posted July 28, 2005 Share Posted July 28, 2005 fitting my new s2 suspension its the 125/135 kit, any tips when doing so etc, anything else i should purchase before doint the job? Link to comment Share on other sites More sharing options...
malbon Posted July 28, 2005 Share Posted July 28, 2005 dead easy. take the wheel off - remove old shock - getting round the back of one to the nut is a bit of a PITA, take it out put ,new one in, put wheel back on. For the fronts do the same but you should need to change the bracket which steve should have sent. you don't need to but is recommended that you put some silicone or something between the bracket and chassis to stop them reacting/corrdoding or something. job done. took me an afternoon - oversteered like a pig so had to have it geod. Link to comment Share on other sites More sharing options...
tonner_notts Posted July 28, 2005 Author Share Posted July 28, 2005 do u recommend using new nuts etc? Link to comment Share on other sites More sharing options...
JohnnyM Posted July 28, 2005 Share Posted July 28, 2005 I changed all bolts and nuts at the time, also make sure you have some copper grease to hand so they dont squeak in their brackets. I also used some threadloc on the bolts so they dont come undone very easily. Enjoy, makes a world of difference ! Link to comment Share on other sites More sharing options...
tonner_notts Posted July 28, 2005 Author Share Posted July 28, 2005 where can i get the nuts and bolts i need? doing it at my mates ford garage, so they should have all the bits i need, Link to comment Share on other sites More sharing options...
daz f Posted July 30, 2005 Share Posted July 30, 2005 Get a geo done straight after, or at least the alignment and camber. I did mine myself and the car drove pretty well after but the alignment was out on the rear. The camber was the main thing that i altered when fitting the s2 stuff. This is done by removing shims that are inbetween the hub carrier and the wisbone. You need to take the measurements out of the service notes for what its set to as standard and then steve B should of given you some rough ideas to what you will need to set it to afterwards. Link to comment Share on other sites More sharing options...
