Bramble111s Posted February 17, 2005 Share Posted February 17, 2005 Never really been interested overly in tyre pressure, but since buying a tyre pressure gauge, arrived this morning, I am now wondering.... Toyo T1-S all round Fronts measured at 22 and 19.5 Rears measured at 24 and 23.5 Gauge should be accurate to within 1 PSI Obviously the fronts seem a little far apart, but is this about what they should be? Bearing in mind that I have just had a service and the pressures should have been set by the garage on Tuesday... Link to comment Share on other sites More sharing options...
malbon Posted February 17, 2005 Share Posted February 17, 2005 Toyos need running a little higher and are sensitive to pressure. I ran 24/28 as opposed to 23/26 on other brands due to side wall flex. Apparently the Toyo R's are a little better. Experiment with them as they can make a big difference. Link to comment Share on other sites More sharing options...
Scott_Mac Posted February 17, 2005 Share Posted February 17, 2005 With T1-S I ran 25/27 and sometimes 24/26 - weather dependant. T1-R are a lot better, i run at 23/25 and there is noticeably less flex. If you can get the T1-S warm and get over the fact that the flex is there you can run them a lot lower.. but experiment to be sure. Link to comment Share on other sites More sharing options...
dobbo Posted February 17, 2005 Share Posted February 17, 2005 Anyone suggest ideal road pressures for A038s ? TIA Chris Link to comment Share on other sites More sharing options...
Scott_Mac Posted February 18, 2005 Share Posted February 18, 2005 I think they are supposed to be 22/24 Chris, but i'd double check on SELOC if i were you... Link to comment Share on other sites More sharing options...
