Martin32 Posted February 10, 2005 Share Posted February 10, 2005 Everytime I depress the clutch pedal it sounds like I'm treading on a cat, the sqeak is getting worse, I've tried spraying WD40 but the sqeak always returns. Someone told me I may need a new bush?! Can anyone advise me if this will cure this irritation, and if leaving it will do any harm? Also is it something that can be replaced/corrected easily? Link to comment Share on other sites More sharing options...
Disco Posted February 10, 2005 Share Posted February 10, 2005 Hi there This link shows you how to resolve the problem http://www.lotus-elise.nl/Mods/Stainless_S...lutchpedal.html Disco Link to comment Share on other sites More sharing options...
Martin32 Posted February 10, 2005 Author Share Posted February 10, 2005 Hi there This link shows you how to resolve the problem http://www.lotus-elise.nl/Mods/Stainless_S...lutchpedal.html Disco <{POST_SNAPBACK}> Fantastic, cheers - have you or anyone out there carried this out - the difficult bit looks like getting the bushes back in as they look a tight fit - the homemade press looks the way to go. Looks like a trip Nick Whale to order the bush kit then to the DIY Centre for a long thread, wing nuts and washers. Link to comment Share on other sites More sharing options...
Disco Posted February 10, 2005 Share Posted February 10, 2005 Haven’t done it myself but it looks straight forward job to do All the best! Disco Link to comment Share on other sites More sharing options...
GCCK Posted February 10, 2005 Share Posted February 10, 2005 It's straightforward as long as you don't mind having your head stuck in the driver's footwell for a while. The "kit" is a standard Lotus part no. Ordered mine from local Lotus dealer but had Horizon fit it. Until you get round to replacingthe clutch trunnion, don't use WD40 on the existing one - it will cause the existing rubber to harden and eventually yield entirely. Use silicon/rubber lubricant. Link to comment Share on other sites More sharing options...
Zircon450 Posted February 10, 2005 Share Posted February 10, 2005 Clutch pedal ... <{POST_SNAPBACK}> Mine started that as soon as I used the car with the hardtop on and the "heater" running. Usual story of bushes, they dry and wear. Hence Nyla type material which have an oily component. Buy an original bush, then find the same item with Nyla characteristics from another supplier. Job done, just put a bit of research in. Link to comment Share on other sites More sharing options...
Gareth Posted February 11, 2005 Share Posted February 11, 2005 Mine does it as well but I don't think I would risk doing the repair myself....plus being upside down, head under the pedals (Lotus position ) is not a very comfortable especially when you are 6'2 Link to comment Share on other sites More sharing options...
Scott_Mac Posted February 11, 2005 Share Posted February 11, 2005 I pulled up at Horizon one day and Mike said, "what the hell is that noise" I replied with "oh its the clutch pedal squeaking" I picked the car up later and its never squeaked since.. no idea what he did, but i don't think he repalced anything. So i'd do that Link to comment Share on other sites More sharing options...
bermudabob Posted February 11, 2005 Share Posted February 11, 2005 My clutch pedal is fine - its my brakes that squeak all the time... Link to comment Share on other sites More sharing options...
Zircon450 Posted February 11, 2005 Share Posted February 11, 2005 My clutch pedal is fine - its my brakes that squeak all the time... <{POST_SNAPBACK}> MMC's by any chance Bob ? Link to comment Share on other sites More sharing options...
bermudabob Posted February 11, 2005 Share Posted February 11, 2005 To be honest, I haven't looked since I got the car... Link to comment Share on other sites More sharing options...
Mark H Posted February 11, 2005 Share Posted February 11, 2005 As Graeme said if you dont want to replace it use silicon/rubber lubricant (Yellow can from Halfords). Might have to reapply it once in a while but it does sort it out. Link to comment Share on other sites More sharing options...
Scott_Mac Posted February 11, 2005 Share Posted February 11, 2005 To be honest, I haven't looked since I got the car... <{POST_SNAPBACK}> As an approximate guess... if its R Reg or earliler it has MMC's. Link to comment Share on other sites More sharing options...
