Steve J Posted November 9, 2004 Share Posted November 9, 2004 How does the 12v power socket come out? - Twist, then pull - Just pull - Press clip in from inside then pull - Falls out on own Don't want to damage it doing the wrong thing. Cheers Link to comment Share on other sites More sharing options...
Dave S Posted November 9, 2004 Share Posted November 9, 2004 Hi Steve You remove the gear knob, Handbrake sleeve and the screw at the rear of the gear linkage tunnel and the two in the sides by the gear lever. Lift the tunnel and the socket is held in with two clips that need to be depressed to allow the socket to be removed. If you are just removing the tunnel then you can just remove the plug with the wires attached. What are you doing ? Fitting a quick shift? Dave Link to comment Share on other sites More sharing options...
Steve J Posted November 9, 2004 Author Share Posted November 9, 2004 Got the tunnel off already, just need to remove the socket. Not yet..... just a little paint job. Link to comment Share on other sites More sharing options...
Dave S Posted November 10, 2004 Share Posted November 10, 2004 Hi Steve I had to repaint mine after Scotland. The paint reacted with the mosquito repelant and all bubbled up. If it does that to paint whats it doing tpo you!!! P.S Fit the quick shift while youve got the tunnel off. One of the more worthwhile mod I think. Dave Link to comment Share on other sites More sharing options...
Steve J Posted November 10, 2004 Author Share Posted November 10, 2004 Is it really that good. Had considered the linkage kit and quick shift but wasn't sure if they were worth the money. Link to comment Share on other sites More sharing options...
