Leeroy Posted September 21, 2004 Share Posted September 21, 2004 I noticed a very fine spray of water coming out of the air vent in my bonnet this morning. I've had a look and the one of the ribs in the rad' has a pin prick sized hole. I've spoken to the Nick Whale & Paul Matey and they are both suggesting about £500 to supply and fit a replacement. A few questions: -Does anyone know of a company that can carry out an in situ' repair as the hole is clearly visible and as most of the 6hrs labour quoted is to remove and replace the clam shell? -I can source a replacement for £135 from EliseParts. Does anyone know a good garage that's capable of carrying out this repair (remove/replace clamshell) so I don't have to hand all my pocket money to Nick Whale? - Should I be ultra brave and remove the clam myself? I've a good engineering back ground but have, until now, been reluctant to attempt removing either clamshell? Link to comment Share on other sites More sharing options...
Scott_Mac Posted September 21, 2004 Share Posted September 21, 2004 Where are you based? I had my rad replaced by Nick Whale, bill came to £670 in total... Horizon Motorsport in Cradley Heath will do it, and do it well... give them a call on 01384 566660... ask them for advice. If you are ok working with cars then it is do-able, but not an amateur job, bleeding the system can be a right pain! Removing the clam is probably the easiest part! Link to comment Share on other sites More sharing options...
Leeroy Posted September 21, 2004 Author Share Posted September 21, 2004 Thanks for the prompt advice. I'm based in Moseley in B'ham. If the clamshells the easy bit, I'm tempted to give it a try. Link to comment Share on other sites More sharing options...
Scott_Mac Posted September 21, 2004 Share Posted September 21, 2004 If you are competent... then go for it. A few folk on here have removed the clam themselves (not me personally) and it wasn't that bad (hey, Matty did it, so it can't be ) AS is ay other problems include draining the system of coolant and i guess getting at the rad. Link to comment Share on other sites More sharing options...
Zircon450 Posted September 21, 2004 Share Posted September 21, 2004 Do give Mike at Horizon a call - I just had a quote from him for sort of similar work (Fan) and it was in my view fair for the work involved and the quality of workmanship you would receive. Link to comment Share on other sites More sharing options...
ally Posted September 27, 2004 Share Posted September 27, 2004 A mate of mine had the samew problem. He has got quite a lot of car experience but he didnt seem to think it was a nightmare job. Link to comment Share on other sites More sharing options...
GCCK Posted September 27, 2004 Share Posted September 27, 2004 Yes, you'll need to remove the clam to get decent access to the rad & pipework around it. Hardest part of clam removal is getting the wheelarch liners free. Need to get the front wheels off, so a trolley jack is a pre-requisite. I know, I spent the latter part of yesterday afternoon (the time when I should have been on part II of the run...) trying to do a rad repair without removing the clam, because I don't have a jack. The service manual gives extremely simple instructions on clam removal. Graeme Link to comment Share on other sites More sharing options...
Scott_Mac Posted September 27, 2004 Share Posted September 27, 2004 You sorted with that now Graeme? Hope its not too serious. Link to comment Share on other sites More sharing options...
Steve J Posted September 27, 2004 Share Posted September 27, 2004 At least now his kids know what to buy daddy for Xmas Link to comment Share on other sites More sharing options...
