Bramble111s Posted September 20, 2004 Share Posted September 20, 2004 I think my alarm keyfob must be running low on battery power, sometimes I need to be really close to the car for it to work. Is this a sign that I need to change, it has been like this a while.... Or will it last another 6 months like this? Also, what happens if it doesn't work at all! I guess I get in and press the stud thing to switch off tha alarm???? Anybody? Link to comment Share on other sites More sharing options...
Mark H Posted September 20, 2004 Share Posted September 20, 2004 Sounds like yer battery is dying. Press it against your chin if it isnt working, when you press the button and you will find the range will be much better. Failing that you can use the stick but a new battery would be better. Link to comment Share on other sites More sharing options...
Scott_Mac Posted September 20, 2004 Share Posted September 20, 2004 You can use the stick... but apparantly you then have to get things reprogrammed by Lotus Get a new battery - about £1.50 from Halfrauds! The chin thing is very weird... saw the clip on Top Gear about it, most odd! Link to comment Share on other sites More sharing options...
atte Posted September 20, 2004 Share Posted September 20, 2004 ive used the stick thing loads of times (before i bothered to read the manual!!) and i never had to reprogram anything. I think that happens if you do it with the key in the ignition or something like that. Link to comment Share on other sites More sharing options...
Mark H Posted September 20, 2004 Share Posted September 20, 2004 Yup you dont have to get it reprogrammed by Lotus if you use the stick, sone it many times, as you say I think its only when the keys in the ignition. If you check your manual its tells you how to reprogram your key should you need to Link to comment Share on other sites More sharing options...
MarkH Posted September 20, 2004 Share Posted September 20, 2004 Yup - change the battery - £1.50 ish from Comet or wherever - but be careful when you put it back in - had to fiddle around with mine for about 15 bl**dy minutes to get it to work properly again. MarkH Link to comment Share on other sites More sharing options...
Bramble111s Posted September 21, 2004 Author Share Posted September 21, 2004 thx guys, not sure about my chin assiting in turning off alarms, but if it works, maybe I can become a car burgler.... new battery time methinks.... Link to comment Share on other sites More sharing options...
