simondann111s Posted September 5, 2004 Share Posted September 5, 2004 On most (normal) cars, rotating the tyres, side to side - front to rear evens out the tyre wear and used to form part of the routeen maintenance. Anyone got an opinion on rotating the brake disk on the Elise. My disks are nearing the limit (24mm) on the front, and whilst I would like to replace all 4 with those sexy ali belled ones, I was thinks or swapping front to rear and spending the money on doing 2 days at Spa next month instead. Pads should be good for one more round of abuse... Any opinions.. Link to comment Share on other sites More sharing options...
jimbo Posted September 5, 2004 Share Posted September 5, 2004 I would - but if your disks are very worn they'll be ridged so you may find your pad isn't contacting the disk evenly. While this isn't necessarily a stopper you'll need to bed them in carefully. You may be better off just getting some cheap ones to see you through - if you're doing 140 up kemmel you don't want to be worring about your brakes ;-) . Link to comment Share on other sites More sharing options...
Simon G Posted September 8, 2004 Share Posted September 8, 2004 I wouldn't, just replace the fronts for now, mutsnuts all the way. Link to comment Share on other sites More sharing options...
Mark H Posted September 8, 2004 Share Posted September 8, 2004 I wouldn't, just replace the fronts for now, mutsnuts all the way. Not anymore, seem to remember a post on Exiges.com saying they had stopped making them. Found it: I had a phone call from Stu mid week and he has told me that he will not be doing any more discs - I wont paraphrase him and get it wrong...so the hunt is on again...anyone know of any alternatives? Link to comment Share on other sites More sharing options...
Scott_Mac Posted September 8, 2004 Share Posted September 8, 2004 I thought that to be the case too.... didn't want to upset Simon though. Link to comment Share on other sites More sharing options...
ipanter Posted September 8, 2004 Share Posted September 8, 2004 Aren't the rear discs smaller than the fronts? (or does it just seem like that as the wheels are bigger?) Link to comment Share on other sites More sharing options...
jimbo Posted September 14, 2004 Share Posted September 14, 2004 no, they are exactly the same (the pad is smaller on the rear) Link to comment Share on other sites More sharing options...
Mark A Posted September 15, 2004 Share Posted September 15, 2004 DON'T rotate discs. The fronts on the rear isn't too big an issue but the opposite way round is a definate NO. As has been said above the rear pads are smaller and as such there is a big area which isn't worn down due to the pads and as such is usually very rusty. Therefore fitting those on the front will effectvly give you little or no braking. Link to comment Share on other sites More sharing options...
