marky_p72 Posted February 16, 2015 Share Posted February 16, 2015 Hi I just wanted to share this as my window has been stuck (luckily up) since last year and after having a baby in November I've only just got round to doing this! It was simply screw 19a from this diagram https://www.deroure.com/diagrams.asp?TBL=5820&MAK=1&MDL=22&SMA=0&SMO=0&ST=&SC=0 that had come loose which was obstructing the channel. However, because the window was stuck up, I couldn't get to it! I had to basically unbolt the window from the lifting mechanism which meant I could then wiggle the window past this screw to get it down, then I could tighten the screw through the now empty slot at the top (near the wing mirror). Result. So, from this I would recommend checking this screw tightness from time to time (and the other one at the back). ! Cheers Mark Link to comment Share on other sites More sharing options...
Gary ZBJ Posted February 17, 2015 Share Posted February 17, 2015 Top tip, had this happen to me but luckily I was able to get the window down, just!!! Link to comment Share on other sites More sharing options...
