courtster Posted February 20, 2004 Share Posted February 20, 2004 My drivers door won't stay open, it's bugged me for a while 'cause I need every limb to get out the Elise and using one to keep the door open doesn't make it any easier! Am I right in thinking its a part called the 'door check strap'? Is it an easy swap? Thanx in advance Courteney. Link to comment Share on other sites More sharing options...
Dave S Posted February 20, 2004 Share Posted February 20, 2004 Hi Courteney There is a door retaining spring I think? Part of the hinge. As far as I can remember its a vertical plate about 9cm high that runs up against the hinge. I might be completely wrong I dont have the parts book with me as I am in the office today but I may be able to post a pic of the hinge and door later on. I have a S2 but I should think that they are the same. If you look at the passanger door you should be able to see the spring move when you open the door. Then check the drivers side, It may just need a little bend with a tyre lever or screwdriver to get it back into shape. Thats all the garage would do. Hope this helps Dave Link to comment Share on other sites More sharing options...
courtster Posted February 20, 2004 Author Share Posted February 20, 2004 Thanx Dave, that would be great, i'll have a look when I get home this evening. Link to comment Share on other sites More sharing options...
Dave S Posted February 20, 2004 Share Posted February 20, 2004 Hi Courteney If you do a search for door hinge in the archives. there is a thread called scraping door. In there someone has posted a page from the workshop manual showing the hinge and the spring plate. Hope this helps Dave. As you can see I am really hard at work this morning. Chat soon Dave Link to comment Share on other sites More sharing options...
courtster Posted February 20, 2004 Author Share Posted February 20, 2004 Cheers Dave, have found it, will try it over the weekend Link to comment Share on other sites More sharing options...
KiwiPete Posted February 21, 2004 Share Posted February 21, 2004 My passenger door had a similar problem. Turned out the spring plate had fractured over time and eventually fell out. If you have the sevice manual it clearly shows the hinge and spring set-up. Cheers Peter Link to comment Share on other sites More sharing options...
