spike Posted February 18, 2004 Share Posted February 18, 2004 getting a metalicy [sp] scrapping kinda noise, which appears to be comming from passenger side front wheel, and only when turning left. i guessed that it may have something to do with the disk shield catching, but ive checked this and the clearances seem fine. it got kinda loud last night, then disappeared aftrer a probe and a poke [fnar lol] now im wondering if it the wheel bearing.... any ideas b4 i take it to NW [need new boots anyway, but id like your thoughts too] spikeyspikeyspikeyspikey [repeat to fade] Link to comment Share on other sites More sharing options...
Dave S Posted February 18, 2004 Share Posted February 18, 2004 Hi Spike If the wheel bearings have got a bit of play then it could cause the disc pad to rub? When did you last check the pads? Hope its not too expensive .. Chat soon Dave Link to comment Share on other sites More sharing options...
KiwiPete Posted February 18, 2004 Share Posted February 18, 2004 Normally with a wheel bearing you can feel it if you jack the car up and hold the wheel top and bottom and try to move it. There shouldn't be any play. If there is look at the hub and you'll soon see where the play is. Also when driving you can often tell a wheel bearing my turning slightly to one side then the other and the noise will change as the load on the bearing changes. At least there not expensive to get replaced. My last one only lasted 10K miles. Link to comment Share on other sites More sharing options...
KiwiPete Posted February 21, 2004 Share Posted February 21, 2004 So what was the verdict??? and cost??? Cheers Peter Link to comment Share on other sites More sharing options...
spike Posted February 21, 2004 Author Share Posted February 21, 2004 appologise for the delay in reply, but thanx for the suggestions no play in the wheel, so im assuming no bearing failure. after the horrific stint of loud grinding, it seems to have vanished. my guess is something was lodged somewhere between the disk / caliper [sp] / disk shield, and i guess its dislodged itself! all seems to be running smooth, but ill get NW to give it a quick once over when im there for new advans cheers again spike Link to comment Share on other sites More sharing options...
Wuddie Posted February 22, 2004 Share Posted February 22, 2004 Spike i had exactly the same problme a few weeks ago..i managed to get to the problem before it went away..it appears that a stone was caught between disk and pad..so dont worry. Link to comment Share on other sites More sharing options...
daves2111s Posted February 22, 2004 Share Posted February 22, 2004 Yep it will be a stone! I get this on a regular basis in my Beemer. Sometimes it's that bad I have to pull over then put it into reverse which usually throws it out. First time it happened called out the breakdown service. Of course when they arrived it fell out and all was ok They commented that it was pretty common with very open spoked alloys. Generally the stone gets trapped between the disc guard and disc. But sometimes it can be a small chipping trapped in the surface of the pad. Dave Link to comment Share on other sites More sharing options...
