Mark H Posted May 13, 2011 Share Posted May 13, 2011 CIRCUIT DE CATALUNYA, BARCELONA, SPAIN General Race laps: 66 Circuit Altitude (m): 129 2010 Air/track temp (˚C): 20 / 33 2010 ATM Press (HPa): 994 2010 humidity (%): 40 2010 wind (kph): NNE 15 2010 Timing Qualify Result P1 WEB 1:19.995 Q3 P2 VET 1:20.101 Q1 P3 HAM 1:20.829 Q1 TL best P19 TRU 1:24.674 Q1 2010 Race Result P1 WEB 1:24.828 L62 P2 ALO 1:24.846 L57 P3 VET 1:25.176 L56 TL best TRU, P17 Quick description Lateral track with high percentage of high speed corners Slow-speed traction important through sector 3 Medium brake energy Bumps at entry to T9 & braking into T10 Grip level changes depending on conditions (rubber, track temp & wind) Typical balance issue: Us in HS T3 and T9 and traction issues in S3 1st gear not used on track Drivers usually prefer to go through T9 without downshifting Circuit particularity - Sensitivities Bumpiness: Medium Engine severity: Low Overtaking chance: Low GBX severity: Low Kerbs: Smooth to medium Lat/Long grip: Lateral RH setting particularity: None Aero eff ratio: Low Track grip evo during WE: High Aero settings: High Brake wear severity: Medium Brake cooling necessity: Medium Safety car history 2010: None 2009: 1st lap accident 2008: 2 Jarno Trulli, Car 21 - Chassis T128-03: "It's always good to get back to Spain. I've spent so much time at the Barcelona circuit it's like a second home to me and the whole team and even though I must have completed thousands of kms around there it's still a good challenge. It's very technical and that puts demands on the car's aero - a good aero package is one of the keys to being quick. "Looking at the circuit itself I particularly like T9 - it's one of the quicker corners in the whole calendar and one that rewards confidence and good balance. There's not a lot of overtaking chances around the lap and we'll see if the DRS plays the same role in Spain that it did in Turkey - if it does then tracks like Barcelona will suddenly have overtaking chances and that's got to be good for the fans." Heikki Kovalainen, Car 20 - Chassis T128-04: "Barcelona is one of the tracks where we all know every single centimetre of the whole lap. We test there so much that it usually ends up with the whole grid having teammates side by side but it's the kind of circuit where you can't hide anything at all. If you are quick there you can be quick everywhere as it's demanding aerodynamically, and if you struggle there you could have problems at a variety of circuits. "A good lap kind of flows until you reach the last three corners which are a bit fiddly. The first sector is probably the best - T1 is a quick chicane and then turns three, four, seven and nine are all fast. You need good high-speed stability there and good grip to get the best out of the car and when you hook it all up and put in a quick time it's pretty rewarding." This post has been promoted to an article Link to comment Share on other sites More sharing options...
