joe_braze Posted June 29, 2005 Share Posted June 29, 2005 just got in my elise s1 , driving down the street and all of a sudden its keeps splutering, kangarooing and has lost loads of power? any ideas on when it is and how much it will be to get fixed! really clueless when it comes to cars so any info will be greatful Link to comment Share on other sites More sharing options...
simonk Posted June 29, 2005 Share Posted June 29, 2005 Could be all sorts of things fuel: crap in it, none left, pump ignition: sensors, spark plugs fouled, leads,distributor cap, rotor arm Link to comment Share on other sites More sharing options...
gerags Posted June 29, 2005 Share Posted June 29, 2005 Sounds like it's misfirinf There's a thread here... http://www.midlandslotus.co.uk/forum/index...?showtopic=4763 But it could be water in the electrical system (Plugs & distributor cap) or the petrol you're using (if you've filled it up recently) Link to comment Share on other sites More sharing options...
Tango190 Posted June 29, 2005 Share Posted June 29, 2005 just got in my elise s1 , driving down the street and all of a sudden its keeps splutering, kangarooing and has lost loads of power? any ideas on when it is and how much it will be to get fixed! really clueless when it comes to cars so any info will be greatful <{POST_SNAPBACK}> Joe, did the car drive fine just before it pissed down tonight, I'll have 50p with you the ignition leads are soaked under the spark plug cover, or the plug wells are full of poopy rain drops. Take a breath, undo the spark plug cover and voila ????? Two minute job even for a non techie. Bob Link to comment Share on other sites More sharing options...
malbon Posted June 29, 2005 Share Posted June 29, 2005 like bob says...if its only started happening after this horrendous weather then it will be rain on your leads and in your plugs. dont worry I just left mine running for half hour to dry it out - problem solved. Link to comment Share on other sites More sharing options...
Tango190 Posted June 29, 2005 Share Posted June 29, 2005 like bob says...if its only started happening after this horrendous weather then it will be rain on your leads and in your plugs. dont worry I just left mine running for half hour to dry it out - problem solved. <{POST_SNAPBACK}> Joe's gone offline Jon, I bet he's having a nosey. I also do a nice line in diagnosing Motorsport Elise remote thermostats - true ? Link to comment Share on other sites More sharing options...
jimbobdunkley Posted June 29, 2005 Share Posted June 29, 2005 ill cut my old boy off its not thaty your dizzy has got wet in the rain!!! Link to comment Share on other sites More sharing options...
malbon Posted June 29, 2005 Share Posted June 29, 2005 yeah...you did ok Link to comment Share on other sites More sharing options...
joe_braze Posted June 29, 2005 Author Share Posted June 29, 2005 bk, sorry bout that, yeah i was having a noesy!!!! i pulled the leads out of the middle of my dizzy cap, and it seems that its broken and decayed!!!!!! i put it back on, wiggled and turned it till it kinda got a bite, took the car round the block and its perfect. so me thinks a new set of leads r needed. s4s280, where do i collect my 50p from! i might need it to put towards my leads if times get hard lol can anyone tell me how much this will be around? and can get it done anywhere or shall i got to somewhere like horrizons? Link to comment Share on other sites More sharing options...
Tango190 Posted June 29, 2005 Share Posted June 29, 2005 bk, sorry bout that, yeah i was having a noesy!!!! i pulled the leads out of the middle of my dizzy cap, and it seems that its broken and decayed!!!!!! i put it back on, wiggled and turned it till it kinda got a bite, took the car round the block and its perfect. so me thinks a new set of leads r needed. s4s280, where do i collect my 50p from! i might need it to put towards my leads if times get hard lol can anyone tell me how much this will be around? and can get it done anywhere or shall i got to somewhere like horrizons? <{POST_SNAPBACK}> Go to Mike at Horizon and get him to fit a set of Magnecors, job done forever, you can also use them as tow ropes !!! Re the 50p - did you bother to check there ? No check no 50p Link to comment Share on other sites More sharing options...
