Snapper Posted May 21, 2005 Share Posted May 21, 2005 I have the Lotus / Momo removeable steering wheel that has a Key and a lock that slide out of the barrel. Problem is that I have lost the lock part some how. Its the little Brass bit.... Does anyone know where I can get a replacement from? I asked at my dealers and they say that they can't get a replacement lock and key from Lotus, because they don't do it as a spare part. I understand its part of whats called a snap off kit. Has anyone got any contact numbers, web addresses that might be of help in my search for this lock and key? Cheers Link to comment Share on other sites More sharing options...
Tango190 Posted May 21, 2005 Share Posted May 21, 2005 I have the Lotus / Momo removeable steering wheel that has a Key and a lock that slide out of the barrel. Problem is that I have lost the lock part some how. Its the little Brass bit.... Does anyone know where I can get a replacement from? I asked at my dealers and they say that they can't get a replacement lock and key from Lotus, because they don't do it as a spare part. I understand its part of whats called a snap off kit. Has anyone got any contact numbers, web addresses that might be of help in my search for this lock and key? Cheers <{POST_SNAPBACK}> Try Peter Smiths Sports Cars - they sorted mine out with a new one. Link to comment Share on other sites More sharing options...
Snapper Posted May 21, 2005 Author Share Posted May 21, 2005 I have had some information sent to me from From SELOC that this lock is also used on caravans as a lock on the towing hitch. And it might be found at Halfords. Been down there but no luck... Anyone able to shed some light? Link to comment Share on other sites More sharing options...
mustard Posted May 22, 2005 Share Posted May 22, 2005 Think Halfords have what you need in the towing section (cetainly looks similar) costs £8.49 HTH Link to comment Share on other sites More sharing options...
Elaine Posted May 22, 2005 Share Posted May 22, 2005 I have the Lotus / Momo removeable steering wheel that has a Key and a lock that slide out of the barrel. Problem is that I have lost the lock part some how. Its the little Brass bit.... Cheers <{POST_SNAPBACK}> Mr Reg (Master Locksmith) says can you post a pic? Link to comment Share on other sites More sharing options...
Alex Posted May 22, 2005 Share Posted May 22, 2005 I have had some information sent to me from From SELOC that this lock is also used on caravans as a lock on the towing hitch. And it might be found at Halfords. Been down there but no luck... Anyone able to shed some light? <{POST_SNAPBACK}> Yep i got mine from Halfords towing section. Then you need to file it to fit. BTW i have a spare one with a single key if you have no luck. Link to comment Share on other sites More sharing options...
Snapper Posted May 24, 2005 Author Share Posted May 24, 2005 Halfords in the Birmingham area haven't got any and have that glazed look when to try to explain what you are after. BUT the good news is that I have now found a supplier who had about 40 in stock. Pucked up four locks and have managed to grind some of the lug off so that they will fit. So if any one requires a new lock and 2x keys I can supply them to you with the modification already done. Just drop me a U2U mail. Link to comment Share on other sites More sharing options...
