daves2111s Posted May 17, 2005 Share Posted May 17, 2005 Heading back from Ludlow 10pm just missed a fox by about 5ft at 70+ Then overtaking a couple of cars whilst following another the throttle stuck open at about 60% thank god it wasn't 100%. I had to follow the guy in front of me in fourth with the brakes hard on. Once he moved ahead I tried the only easy option and blipped the throttle again fortunately that sorted it. When I got home I found the cause.... the small wiring harness to the bootlid closure sensor had moved away from the boot bulk head and it had caught the end of the throttle cable cam on the side of the throttle body. If you have an S2 it might be worth checking this one.....it could have been a lot worse Link to comment Share on other sites More sharing options...
Tango190 Posted May 17, 2005 Share Posted May 17, 2005 Failing that, there may be a 5ft tall, 70mph Fox in there Not a funny experience I'm sure Link to comment Share on other sites More sharing options...
Fiona Posted May 18, 2005 Share Posted May 18, 2005 Bloody hell - that sounds a bit scary . Will check it out later. Link to comment Share on other sites More sharing options...
Ben (T25) Ruz Posted May 18, 2005 Share Posted May 18, 2005 thanks for the heads up mate...off to check mine now (as I had a sticky throttle the other day). Ben Link to comment Share on other sites More sharing options...
jez_s Posted May 18, 2005 Share Posted May 18, 2005 Yep shall be checking mine soonest......is it worth telling Lotus (not that they'll give a monkeys!). Link to comment Share on other sites More sharing options...
