Ladders Posted November 10, 2004 Share Posted November 10, 2004 Are these the same as the Lotus OE covers? Just wondering as the OE are about £80 and Eliseparts are £50 Are the OE ones better quality at all? Link to comment Share on other sites More sharing options...
malbon Posted November 10, 2004 Share Posted November 10, 2004 whats wrong with your olds ones ? just buff them up and get some new tape. they're gonna get doity anyway ! Link to comment Share on other sites More sharing options...
Ladders Posted November 10, 2004 Author Share Posted November 10, 2004 Theyre about as chipped as the rest of the front end Jonno! Will need a new set for when I get the front resprayed. Link to comment Share on other sites More sharing options...
GCCK Posted November 11, 2004 Share Posted November 11, 2004 Worth checking if they're the right ones. Aftermarket items designed for std S1 are a slightly different fit to the pukka 111s covers. Link to comment Share on other sites More sharing options...
lesstatt Posted November 11, 2004 Share Posted November 11, 2004 I'd like some on mine, think they look great, but ive been put off by negative comments about fitting them properly and getting them to seal, dirt getting behind them and condensation misting them up, so even though they look great im not bothering now Link to comment Share on other sites More sharing options...
enxrjm Posted November 11, 2004 Share Posted November 11, 2004 I've got the eliseparts ones that are held on by 3 pins rather than tape. The first set I got fitted really well but I cracked one and the replacement is a shade too large. Its not too noticeable but if it'd worry you probably best to get from somewhere else. Link to comment Share on other sites More sharing options...
Sol Posted November 11, 2004 Share Posted November 11, 2004 Ladders, I got mine from lotusecosse.com for £35. They do both the S1 & 111s versions. Mine are the S1 model and fitted perfectly! As for quality, I have no complaints. I would guess the Eliseparts ones are prob the same thing, except I have noticed Eliseparts do tend to charge more for some of the "basics". Alan, mine were put on with double sided heavy duty velcro from B&Q and took about 10 minutes(mainly cutting the velcro to shape). Easiest thing ever! (Considering you have done the exhaust yourself, it would be a piece of p!ss) I was afraid they would fly off, but did a few thousand miles no probs. As for misting, yep they do sometimes but its not a huge issue. Dirt - yep a little because its not fully sealed, but they are so easy to remove and refit with velcro (none of that dodgy making holes in clam stuff) Since my new clam from Sinclaire, they fitted the removable ones that allen key open. Same thing tho..hth Link to comment Share on other sites More sharing options...
steve Posted November 11, 2004 Share Posted November 11, 2004 Ive got the allen key type ones too - they are great. I'm thinking of getting some thin draught excluder to try and create a seal and prevent dirt from getting in. Either way - only takes a couple of minutes to get them off. steve Link to comment Share on other sites More sharing options...
Ladders Posted November 11, 2004 Author Share Posted November 11, 2004 Wasnt sure whether they wer made form diffrent material at all? Like Richard said, he managed to shatter one of his and there's no way I could see the origonals on mine shattering - to tough! Link to comment Share on other sites More sharing options...
enxrjm Posted November 11, 2004 Share Posted November 11, 2004 they only shattered when I drilled them with a normal drill bit. Got one of the techs at uni to do the second one and he used a drill bit with a really drawn out thread which cut through no problem. Was very nervy drilling the clam but now its done they are easy to remove and clean and dont mist up. But as I said - quality control not the best from eliseparts Link to comment Share on other sites More sharing options...
