Ladders Posted November 10, 2004 Share Posted November 10, 2004 Will I be able to get it out by removing the rad cover or is it a case of removing the wheel arch liners or even the front clam Link to comment Share on other sites More sharing options...
GCCK Posted November 11, 2004 Share Posted November 11, 2004 If it's where it sounds, it's just behind the wheelarch liner. Link to comment Share on other sites More sharing options...
RobC Posted November 11, 2004 Share Posted November 11, 2004 It'll be in one of the front corners of the clam, just peel back the wheel arch and hook it out Link to comment Share on other sites More sharing options...
Ladders Posted November 11, 2004 Author Share Posted November 11, 2004 Great, just have to undo all those rusty Rawl bolts now then! Link to comment Share on other sites More sharing options...
Zircon450 Posted November 11, 2004 Share Posted November 11, 2004 Great, just have to undo all those rusty Rawl bolts now then! <{POST_SNAPBACK}> Dave - give me the spec on the tyre foam - just checked mine - I don't have one - unless its hiding where yours is ! Link to comment Share on other sites More sharing options...
Ladders Posted November 11, 2004 Author Share Posted November 11, 2004 You just need to pop to your local motor factor and get whatever tyre repair stuff they've got, it's all the same really. Link to comment Share on other sites More sharing options...
RobC Posted November 11, 2004 Share Posted November 11, 2004 Which part of "peel back the wheel arch" did you miss No need to undo anything, just put the steering on full lock and pull the liner down. Job done (30 seconds) Link to comment Share on other sites More sharing options...
Ladders Posted November 11, 2004 Author Share Posted November 11, 2004 Which part of "peel back the wheel arch" did you miss <{POST_SNAPBACK}> All of it! I shall give that a try then, which bit do you peel btw? Link to comment Share on other sites More sharing options...
Zircon450 Posted November 11, 2004 Share Posted November 11, 2004 Which part of "peel back the wheel arch" did you miss <{POST_SNAPBACK}> All of it! I shall give that a try then, which bit do you peel btw? <{POST_SNAPBACK}> Knuckles I suspect Link to comment Share on other sites More sharing options...
shortname Posted November 13, 2004 Share Posted November 13, 2004 Had the same problem a while ago. Spent ages worrying about what the clunk from the front end on cornering was! Should be easy to recover with a bit of James Herriott type groping. I wired the can to the clip to prevent repeat performances. Was also surprised to see that the can supplied was too small for the rear tyre (!) so bought the next size up. Link to comment Share on other sites More sharing options...
