steve-n Posted September 16, 2004 Share Posted September 16, 2004 Last night i went to stick my bag in the boot and found that the spring locator and a black mounting plate had parted company with the lid. Any ideas how these to fit together?? I'm thinking the mounting plate fits somehow into the lid?? any info will be helpful !! Link to comment Share on other sites More sharing options...
thub Posted September 16, 2004 Share Posted September 16, 2004 If I'm picturing the right parts, the black plate isn't flat, and has a thread in its centre. That part needs to be slid into the slot in the boot lid. The spring shaft can then be screwed into the plate to hold the whole assembly in place. Now that's all from memories of adjusitng it a year ago, so I'm sure I've missed some pertinent points! Link to comment Share on other sites More sharing options...
steve-n Posted September 16, 2004 Author Share Posted September 16, 2004 Ok, cheers for that, thought as much, its going to be a little bit of a tricky job........"something for the weekend Sir???" Link to comment Share on other sites More sharing options...
steve Posted September 16, 2004 Share Posted September 16, 2004 Just make sure that when you do the final tightening, that it is definitely in the right place because if its not......... hth steve Link to comment Share on other sites More sharing options...
thub Posted September 17, 2004 Share Posted September 17, 2004 Use some masking tape or paper over the lower half of the lock so you can bring the spring section down carefully and make sure it's lined up properly. Good luck. Link to comment Share on other sites More sharing options...
