Adding Images To A Post
There are two ways you can do this.
Option one - Attaching an image
You can attach an image to a post but the maximum size it can be is 100k.
- Click add reply to a topic (You cant add an image from the fast reply box at the bottom of a page)
- Under the File Attachments section, press the browse button and point it at the image you want to upload from your PC
- Select the "Add this attachment" button and wait while it uploads.
If that fails check the image size is less than 100k, you can add more than one image per post.
Option two - Linking to an image
In the text editor box you can click the icon:
And then paste the url into the box and that will add the tags automatically for you.
This will add the image to the post.
Alternatively failing that if you find out the url of the image you want to link to, like this for example:
http://www.midlandslotus.co.uk/forum/uploa...5_39_881788.jpg
Right click on the image and select properties to get the url like above
Then enclose the link in the following words
[img]
and close it with
[/img]
so like this:
[img=http://www.midlandslotus.co.uk/forum/uploads/gallery/1114621436/gallery_655_39_881788.jpg]
This will link directly to any image on the internet, give it a go you can always go back and edit/delete your posts anyway.
Gallery images
If the image you want to link to is already in our gallery then:
Click on "options" and then "share links"
Select and copy the text for "BBCode"
The link can be posted straight into a post as the tags have been added automatically already.
  • 1 year later...
  • Replies 1
