  • entries
    3
  • comments
    2
  • views
    26,794
Engine Removal
Dazzx10r
After marking up all of the electrical conections and removing the exhaust, gear shift cables, clutch slave cylinder and throttle cable the engine was finally rready for lifting out, I had a bit of trouble removing the o/s engine mount and the bottom gearbox mount as they were siezed in but luckily a bit of heat from the old oxy/propane soon sorted this smile.png I have a lifting beam in my garage and a 1.5t block and tackle, so lifting the engine out was a doddle!
0 Comments
